Actually, it's the damper installation tool adapter end that screws into the crank snout. It's broken off with about 1/2" of threads stuck in the hole I was going for the "easy outs", but this must be a hardened piece, as my titanium drill bits cannot drill through it It's in there flush with no part to partially grab and work it out......HELP.....any suggestions (other than getting a new crank)???.....also I still believe the damper has another 1/8" or so to be fully seated; why would it get so tight as to break the tool before sliding on? (This is a Snap On installer, not a cheapie.) Are all 383-400 balancers that tight?........Thanks in advance for replies.
I had 1 break in the crank too, fortunately a little was hanging out. The piece left in the crank won't be tight, it is much shorter than the threaded hole. Try using a thin screwdriver to walk it out. Spray a little lube in if necessary. Good luck.
Thanks for your replies.......bought a reverse drill bit extractor today; will try a sharp punch to turn/hammer it first...will try to tack weld an attachment on the stuck piece as a last resort....
I did this several months back, had the same thing happen to me. Get a reverse drill bit, drill a pilot hole in the center of the broken bolt and tap the the reverse bit in about 1/2" and back it out with a small combination wrench or an adjustable wrench. It should come right out, the bolt that comes in those damper installation kits are softer than you think. Did you just replace your timing chain?, if so the crankshaft gear is probably not seated all the back on the crankshaft, that was the problem on mine. Pull the timing chain cover and make sure it it all the back on the shaft. If it doesn't want to go check to make sure the woodriff key is not in on an angle and causing it to hang up. The woodriff key must be straight and it will go on with no problem. Also be sure to oil up your timing chain real well before putting the cover back on. Hope this helps.
Thanks for the good advice.....this seems like an extra stubborn case, as I did not change the timing chain (only the cover). I positioned a mirror so I could see under and behind the damper and it appears to have 1/8" to go......NONE of my bits (cobalt or titanium) will drill through this broken bolt.....(still trying)......BTW, how do you "plug weld" a nut to the end piece?...
center a nut about the same size as the broken bolt over the bolt. the inside of the nut where the threads are should be smaller than the broken bolt outside diameter. take a welder and weld the inside of the nut hole to the face of the broken bolt. there is alot more area to weld on the inside of the nut than you think. the suggestion to use an anti-splatter spray is a decent idea, but if you are careful....
after the nut is welded to the broken bolt, take an appropriate sized wrench and twist the nut and broken bolt combination out.
i have done many plug welds, but never on a broken bolt to get it out; never thought of it until it was mentioned here.
This seems to be a good remedy, however the broken piece in mine is countersunk about 1/2" inside the bolt hole, around an inch deep into the crank snout.....a nut would disappear inside, not accessible with a wrench......Maybe thinking a small tube or metal piece I can grab and use as a handle might work.....still searching for a bit that's able to drill through hardened steel so I can use an easy-out.......tried chipping with a punch; not enough room to get an angle to chip.....nothin's moving......
I had exactly the same thing happen not too long ago. I was able to push the part that came out against the part still in the crank and slowly turn it out. The two surfaces matched up and the threads were loose so that worked for me.
If that doesn't work, here's another idea you might try. Put a drop of Super Glue on the broken surface and glue the halves together. If the half in the crank is fairly loose, you might just get lucky.
From: A high school diploma fixing what a college degree broke TN
Originally Posted by Twin_Turbo
Get a nut and plug weld it on the piece that's still in the crank. I'd use anti spatter spray on the crank to be safe
I wouldn't do this until my last resort.When I was going to get my welding certification,this was covered one day and a guy had done some welding on a block,hooking the ground up to the crank snout.What running all that electricity thru the crank did to the bearings wasn't pretty I realize you aren't doing exactly the same thing,but keep in mind where you ground everything
I had the same thing happen to me, after I installed the damper. I tried to weld a grade 8 bolt to the broken piece, and that snapped. I GRINDED the section flush where the bolt goes into the crank and left it like that, I didn't want to take the chance of not drilling strait. and having to remove the crank, seeing mines a stroker and balance is a bit more important.. so I quess the only way to do a cam swap will be to remove the crank..
