Fuel injection conversion Q's....
Old Oct 2, 2005 | 07:32 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Default Fuel injection conversion Q's....
With the price of gas these days,I need to get better mileage, so I am considering making the switch to fuel injection. What systems are out there, and are some better than others? What does C3 Tech recommend?
Old Oct 2, 2005 | 07:42 PM
fl_rider's Avatar
fl_rider
Default Here is a link...
http://forums.corvetteforum.com/show...084&forum_id=3
This will give you a little insight and more information.
Chris B
Old Oct 2, 2005 | 07:45 PM
Gordonm's Avatar
Gordonm
I can't remember if you have an overdrive trans or not. If not this would save you more fuel. A properly setup carb vs. fuel injection will only net you a few mpg. Not worth the expense. Now for driveability the fuel injection is the winner hands down.
Old Oct 2, 2005 | 07:52 PM
7t2vette's Avatar
7t2vette
thanks Chris, but I don't think I want to go with a TPI setup, my motor goes to 6000 rpm now, and aren't the TPI's done by 5000 rpm? I was thinking aftermarket.
Old Oct 2, 2005 | 07:53 PM
7t2vette's Avatar
7t2vette
No, I have a TH400,so a Tremac TKO is also on the books. Hell, just switching trannys should net me 30hp, forget about mileage!
Old Oct 2, 2005 | 08:04 PM
big_G's Avatar
big_G
Get a T.P.I.S. mini-ram or other system like the C-4 LT1. They pull past 6 grand with a 52 mm. throttle body. A good choice, IMO.
Old Oct 2, 2005 | 08:07 PM
7t2vette's Avatar
7t2vette
Can they bolt on to normal SBC heads, or are mods neccessary?
Old Oct 2, 2005 | 08:11 PM
big_G's Avatar
big_G
Yes, they were originally designed for use on early sbc engines...
Old Oct 2, 2005 | 08:15 PM
7t2vette's Avatar
7t2vette
Just checked out the TPIS website........mini ram setup is $3700! Yikes, I didn't know it would be that expensive. It would almost be worth finding a LS1 with wiring and computer from a wreck instead!
Old Oct 2, 2005 | 08:21 PM
big_G's Avatar
big_G
I didn't say it was cheap
Holley and Edelbrock both sell systems less expensive, fyi...
Old Oct 2, 2005 | 08:23 PM
zwede's Avatar
zwede
Holley Commander 950. It's a high flow single plane. Pulls way past 6k. Complete kit minus distributor is about $2200. Use a stock GM 8-pin distributor, ~$150 rebuilt from your local parts store with new cap, rotor and coil.
If you're on a budget a Commander 950 TBI kit gives you most of the advantages of the port system and you save almost $1000.
Old Oct 2, 2005 | 08:43 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
www.lt1-intake.com (or something like that) has info on converting an LT1 intake to use on a standard SBC.
Old Oct 2, 2005 | 09:03 PM
Techno's Avatar
Techno
Due to 3 constraints I'm building my own intake. Low end long tubes, high end short tubes. That solves the choice problem. Slide valve to open the short ones.
Reasons.
1: I'm a cheep bastid and aint' spending thousands on doing this.
2: pretty much restricted with what I can buy for a BB
3: I want my cake and eat it too.
Old Oct 2, 2005 | 10:00 PM
7t2vette's Avatar
7t2vette
I will check it out, thats a little better $ wise. I have a full MSD ignition now, will my MSD distributor work with it? What advantages does the TBI setup give up?
Old Oct 2, 2005 | 10:31 PM
zwede's Avatar
zwede
The old style distributor with weights still works just like now. Problem is you loose timing control. With an 8-pin distributor the Holley computer controls timing.
The TBI uses the same computer so you have the same adjustability. The only thing you give up is the slightly better distribution of MPFI. A little crisper throttle response, mostly. Theoretically MPFI gets better mileage and makes more power. I'm not convinced the difference is enough to be measurable.
Old Oct 2, 2005 | 10:54 PM
PatsLs1vette's Avatar
PatsLs1vette
its a shame your running a 406 cause ill have my complete tpi setup,everything needed to drop onto a enigne and run for sale at the end of the month.
87 t/a intake manifold,plenum,throttle body, runners,wiring harness,computer with custom prom,maf sensor and all sensors,dist.,24 lb motorsport injectors and an inline fuel pump also.
Old Oct 3, 2005 | 01:46 AM
stickboy's Avatar
stickboy
I am running a TPIS miniram with and Accel DFI ECM. It's actually a little big for the 350, but will work great once I get my 406 built. Just waiting on the money right now
To Fuel injection conversion Q's....
Old Oct 3, 2005 | 12:00 PM
flynhi's Avatar
flynhi
A readily available TPI with ported plenum and oversized runners matched with a 52mm TB and 24# injectors will easily support well past 5500 rpm. You will need a custom chip for a Speed Density version.
Serviceable by GM dealers or any shop with a decent set of diagnostic tools.
INHO, this combo performs very well, is less expensive and expands your market for resale (most buyers aren't sophisticated enough to deal with aftermarket systems like Edelbrock, FAST and Accel).
Old Oct 3, 2005 | 12:08 PM
ft laud mike's Avatar
ft laud mike
Sorry all, just curious if anyone has ever run a big block f/i setup?
Techno, you have more b***s and knowledge than me to do your own
im looking for something pre-made. I like the factory ram/502 but i doubt it would fit under the hood (11" total)
mike
Old Oct 3, 2005 | 09:01 PM
Techno's Avatar
Techno
The system I'm trying for has to clear the hood without using the scoop. Want to use the scoop for ram air so that is a no zone area.
Not sure but 11" might be in the zone with a hood scoop, it might clear for you.
This all depends on how good I am at sand cores. Haven't really done them yet but seems simple enough. Cast the individual pipes and weld those together. The alternative is build them like an exhaust system but didn't like the cost of prebent aluminum pipe.
BTW my Ba!!s aren't that big. The intake with carb are left untouched so next year I can bolt it back on
