Trany stuck
Old Oct 3, 2005 | 12:19 PM
Deep sea vet's Avatar
Deep sea vet
Default Trany stuck
I have a four speed and the trany is stuck in 3rd and will not come out. the cluch works. I think it might be a linkage problem. any info would help
thanks
Old Oct 3, 2005 | 01:48 PM
73383's Avatar
73383
Check your shifter linkage. If it is worn of out of adjustment it will cause this to happen.
Old Oct 3, 2005 | 02:22 PM
Deep sea vet
Thanks I'll check it out what part of the linkage. under the shifter or at the trany
Old Oct 3, 2005 | 10:04 PM
vabeachvette's Avatar
vabeachvette
Had the same thing about 5 months ago, but was stuck in 2nd (luckily) I was able to drive it home and just had to give the linkage an adjustment just like mentioned above. Might need a second person to move the stick while you adjust the linkage. Good luck.
To Trany stuck
