My T5 swap update
Jeff
PS...you are not far away from me...Doug from Waterloo
We cut our drive shaft to 27 inches outside of universal to outside. Need welding or something on your crossmember. Bring in along. Doug and I welcome company.
The main problem I had was trying to locate a truck bellhousing like the one you used for your swap. Had no luck trying to locate one. I ended up using a standard bellhousing from a 4 spd car and clutch fork as well. I had to make a special brkt for the slave cylinder mounting.
I modified the original tranny mount for the 350 turbo (my car was auto) and used it for the rear tranny mount for the T5. There are some clear pics of this.
Picked up various parts along the way, mostly gahtered info from posts here on the forum. I sent Doug an e-mail with the pics I have, hopefully he can post them for me, one picture is worth a thousand words.
Jeff
Jeff
He would be really interested in the picture of your slave cylinder mount. He also used a standard bellhousing without the mount.
By T5 do you mean a mustang T5 or the gm version???
T5 is Mustang version, followed your original setup that you used for your car, just couldn't get the truck bell housing, had to use a standard one. E-mailed Doug, he is going to post the pics that I sent him.
Jeff
Come and visit Doug and I saturday and bring the adapter plate and the hydraulic clutch plate and let me trim them down into something that is more sleek. Cut out unwanted material.
You really move ahead on the project and glad to see it worked out for you.
Hopefully Doug will have his running saturday and doing a test run.
If you need any welding on the crossmember bring it along also and I would gladly mig weld it for you.
NO CHARGE
Thanks, Les
The cost of this swap really depends on what you source out second hand and how far you want to go. If your car is auto or manual etc. My car was an automatic. Bellow is a brief summary of what I have spent so far:
Standard chevy bellhousing (swap meet) $75
Clutch pedal set from manual vette (used) $200
Flywheel from manual vette (used) $50
Flywheel resurfaced at machine shop $40
Heavy duty clutch assembly $200
Clutch slave cylinder $120
Drive shaft shortened $120
Adapter plate tranny (material) $20
Slave cylinder brkt (material) $10
New throw out brg $30
Lakewood pilot brg $30
Used clutch master cylinder $40
Used T5 tranny and shifter (swap meet) $150
Rebuild for T5 tranny $350
Hardened gear set for T5 tranny $300
Adapter for Ford T5 to chevy speedo $70
Wow!! didn't think I had that much into it. Total is approx $1805 CAD
Things add up over time
Jeff
Bernie read this carefully. Cut about an inch off the front of the bearing retainer to gain disc clearance.
Doug took pictures last night but his camera is still in the shop
Jeff
Jeff
The new ones are steel. A hawksaw makes short work of it.
Bernie
