Q Jet Install
Old Oct 4, 2005 | 12:28 PM
runamuck's Avatar
runamuck
Cruise-In V Veteran
Senior Member
Default Q Jet Install
Anyone have a picture of hose routing on 1971 LS5 Q Jet?? I am changing the present setup back to original and could use any advise out there to insure it goes back correctly. Many Thanks Runamuck
Old Oct 4, 2005 | 05:08 PM
fast idle's Avatar
fast idle
pvc goes to the front bottom(big hole), distributor goes to small hole in lower front,brake booster in the rear large hole. the rest just go where they will fit.
Old Oct 4, 2005 | 08:41 PM
71redskin's Avatar
71redskin
everything he said excet i have the vac line from my dist. connected the side next to my choke assembly. that gives me manifold vacuum not ported, which is what you'll get at the front connection
To Q Jet Install
