Help withadjusting the clutch starting switch
Old Oct 4, 2005 | 07:59 PM
Motor City Vette's Avatar
Motor City Vette
Default Help with adjusting the clutch starting switch
Does anyone know how to adjust the switch (I think it's called the neutral starting switch???) for starting the car with a clutch? It's the swich against the firewall that the clutch connects to so that when you depress the clutch the engine will turn over. I installed a new clutch and now I can barely get the car to turn over because I have to press the clutch all the way down...waaaaayyyyyy down.
EarlierLink in C3 Tech
Old Oct 5, 2005 | 08:55 PM
Motor City Vette
Ttt
Old Oct 6, 2005 | 09:10 AM
Fevre's Avatar
Fevre
Believe the switch has slotted bolt holes in it so you can adj it.
To Help withadjusting the clutch starting switch
