Tach and Speedometer Lens Replacement '72
Old Oct 5, 2005 | 01:02 PM
atlantajoe's Avatar
atlantajoe
Default Tach and Speedometer Lens Replacement '72
Hello All,
Just wanted any advice from anyone who has replaced the lenses on their speedometer and tachometer. I have a '72 convertible and I'm going to replace the radio and dye the dash panels, so I thougth that I'd replace these lenses.
1. How hard is it to drop the steering wheel? Does the steering wheel need to be dropped in order to pull the driver's side dash pad?
2. Once the dash pad is dropped, what do I have to do to replace the lenses?
Any helpful tips would be appreciated.
Thanks in advance
Joe
Old Oct 5, 2005 | 01:47 PM
68/70Vette's Avatar
68/70Vette
Once the driver's front panel is removed, it's easy to replace the lenses. The speedo and tach are screwed into bosses on the inside of the panel. Remove the speedo/tach and you'll be looking at the lens. The various Corvette parts houses sell them. At this juncture, the lenes are really easy to replace.
Getting the panel out ...and then back in is difficult. Yes you have to drop the steering wheel. You have to loosen it where it's bolted just behind the panel. Also, I think you can get some additional clearance by loosening it where it goes through the firewall.
When you first loosen the panel and pull it a couple of inches away from the dashboard, you have to reach inside and push a small button on the side of the headlight switch. This releases the **** which releases the panel from the headlight switch. You have to lay on your back to undo the tach and speedo cables. On some C3's they unscrew and on some C3's they're held on with a clip.
The plastic substrate of the panel is now, due to age, very brittle. If you do very much tugging or pulling on the panel there's a danger of cracking it. Do everything very gently.
Old Oct 5, 2005 | 04:34 PM
atlantajoe's Avatar
atlantajoe
Thanks for the advice- sounds like I'm going to have alot of fun with this!
Joe
Old Oct 5, 2005 | 07:25 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by 68/70Vette
Once the driver's front panel is removed, it's easy to replace the lenses. The speedo and tach are screwed into bosses on the inside of the panel. Remove the speedo/tach and you'll be looking at the lens. ... Do everything very gently.
here is what you'll be looking at once the drivers IP has been removed, and it's laying face down:
http://home.woh.rr.com/mikemercury/pics/01sm.JPG
Old Oct 5, 2005 | 10:43 PM
Edzred72's Avatar
Edzred72
All above advise is right on. One thing to add...make sure those new lenses are squeeky clean before you button it all up. No lint, dust, smudges, streaks, fingerprints etc...
Don't ask me how I know...
Eddie
Old Oct 6, 2005 | 08:56 AM
atlantajoe's Avatar
atlantajoe
Thanks for everyone's advice and great pics. I'll try to take some pics myself during the process. Wish me luck!
Joe
To Tach and Speedometer Lens Replacement '72
