torque convertor
Old Oct 6, 2005 | 10:48 PM
gator79's Avatar
gator79
Default torque convertor
who makes a good stall torque convertor for a lock up turbo 350. I am tired of putting it in neutral or holding the pedals to idle, plus I think it will put a little more fun in the driving. it is 1981 with a 383 and 292/500 lift cam stock rear gears. i was thinking about a 2500-3000 stall
Old Oct 6, 2005 | 11:54 PM
Eric R's Avatar
Eric R
When I did mine, the tranny shop recommended that a TH350 be installed as the selection of converters was greater. As I recall they only dinged me $350 for a rebuilt tranny with a transgo shift kit and hardened sprag. I bought a TCI stall from Summit Racing. You should contact TCI for more insight on your options.
Old Oct 7, 2005 | 12:02 AM
Ironcross's Avatar
Ironcross
If your switching feet between the gas and brake pedals to keep it runnibg in gear, you definately need a good converter. TCI and B&M are a couple of the more popular converters. 2800-3000 stall and a nice respectable idle at around 800 with a solid lifter cam will bring back the joy of an automatic. A little creap in gear is easily handled with light brake pressure.
Old Oct 7, 2005 | 12:13 AM
gator79's Avatar
gator79
Default limited selection
I already went through this trans, shift kit added already. the selection is limited what about hughes? anyone used theirs before?
http://store.summitracing.com/defaul...=egnsearch.asp
Eric, I am also an ASE master tech. you almost have to be to drive a C3
Mark
Old Oct 7, 2005 | 01:58 PM
gator79's Avatar
gator79
Default the only one?????
hughes is the only one I found so far, can this be right? surley someone else makes one
Old Oct 7, 2005 | 02:26 PM
Ironcross's Avatar
Ironcross
If you would read the answers to your original post you would have seen others
djgrelli's Avatar
djgrelli
I personally lke the B&M Hole shot converter. Just installed a 2400 in my son's 23 T-Bucket. We couldn't hold it back in gear and it solved all our problems.
Old Oct 7, 2005 | 09:53 PM
gator79's Avatar
gator79
Ironcross please explain your comment
Old Oct 7, 2005 | 10:16 PM
Ironcross's Avatar
Ironcross
Simply stated, your post asked for names of stall converter companys. I originally suggested TCI and B&M, two of the more popular performance trans parts suppliers. You had found only Hughes.
Old Oct 8, 2005 | 12:12 AM
VETTEVIC's Avatar
VETTEVIC
I would go with a B&M myself. I have destroyed many other brands with my 452ci mopar. If your having problems finding one its because of the LOCK-UP. Its made to lock the trans and converter at highway speeds for better fuel mileage. performance torque converters usually dont come with a lock-up function because of the intended use of the converter.
vic
To torque convertor
