VBP? What spring is this?
Old Oct 7, 2005 | 08:11 PM
Jclgodale3's Avatar
Jclgodale3
Default VBP? What spring is this?
VBP or anyone. Can you tell me what rear spring this is? It is a VBP spring with these numbers across the bottom left of the sticker but part of the sticker is covered by the left mount and can't find a part number
300 330 360 420
Also, what is the best location of the 4 available for the bolt on these brackets as far as stiffness and bounce?
Old Oct 7, 2005 | 08:17 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Looks like a dual mount. I'd say it's at the 330 setting. I believe if you move it towards the wheels that is would become stiffer.
Old Oct 7, 2005 | 08:39 PM
Jclgodale3's Avatar
Jclgodale3
sooo...being the dual mount means I can set it at 300lb, 330lb, 360lb or 420lb??? Is this a good setup?
Was on the car when I bought it so I'm learning...
Old Oct 7, 2005 | 08:49 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Vette Brakes Dual Mount Spring
Old Oct 7, 2005 | 10:16 PM
zwede's Avatar
zwede
If yours is one of the ones that doesn't get bouncy with a fiberglass spring, then yes it is good. Some C3's (like mine) got horribly bouncy and I went back to a stock steel spring because of the bounce.
Old Oct 8, 2005 | 12:06 AM
Jclgodale3's Avatar
Jclgodale3
it's bouncy...mostly over low speed sharp bumps
Old Oct 8, 2005 | 12:23 AM
b71vette's Avatar
b71vette
Default I believe the bounce can be cleared up with the proper
shocks, I understand Bilsteins work good, but Van Steel recommended the adjustable QA1s with the dual which is what I have. Haven't driven it yet so I can't speak from fact though. Maybe some else can tune in that has the dual mount.
Old Oct 8, 2005 | 07:33 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Yes, its a VBP dual mount spring .... I have mine set at the softest setting (300 - inside hole) and it does bounce some but not as bad as some people's. The key is the shocks and how well it is matched with the front springs. I run KYB2's ... had Bilsteins on it, but they were just TOO stiff for the horrible roads around my house. Actually handles better now on these bad roads, because the wheels stay in contact with the surface better and is more predictable.
To VBP? What spring is this?
