1972 no instrument lights
Old Oct 8, 2005 | 08:40 AM
jp96's Avatar
jp96
5th Gear
Default 1972 no instrument lights
i have a 72 and the instrument lights just stopped working all other lights work , i changed the 5 amp fuse and still no luck , could it be the headlight dimmer switch, or a ground.... has anyone had this problem, anyhelp would be greatly appreciated
thanks
Old Oct 8, 2005 | 11:39 AM
GTR1999's Avatar
GTR1999
I doubt all the lamps went out at once. They are the gray wires BTW. There is a black ground wire that pushes on the back of the dash be sure you have it connected. Quick check use a jumper wire from ground to the metal plate where the lamp socket goes to see it they work.
Does the left signal work? That's grounded off the same circuit on the dash. Use a 12 meter or test light to see if you have power at the sockets.
Gary
Old Oct 8, 2005 | 05:49 PM
jp96's Avatar
jp96
5th Gear
Gary thanks for the tip i will check it out. the left blinker works fine.... all the other lights work fine, although i did have to take out the bulbs of the backup lights as it was blowing the fuse but this was well before this instument light problem
Old Oct 8, 2005 | 06:28 PM
jlaw68's Avatar
jlaw68
just fixed a 69 with no dash lights. first thing the dimmer part of the headlamp switch had a burnt spot in it. but the problem ended up being a loose grey wire behind the dash that was flopping around and grounding out and blowing a fuse. drove me nuts for a while
Old Oct 8, 2005 | 06:29 PM
GTR1999's Avatar
GTR1999
If that fails look at the switch.
Old Oct 9, 2005 | 01:46 AM
Kilroy1024's Avatar
Kilroy1024
The "loose gray wire" may be the potentiometer wire for adjusting the dashboard lamp intensity. Its normally coiled up and wound around the front of the switch. As you rotate the headlight switch, a wiper arm sweeps across the top of the coiled wire. I was able to wind mine back up again and glue it back into the switch.
To 1972 no instrument lights
