'77 Coupe has poor handling
Old Oct 8, 2005 | 12:56 PM
KNicholas2's Avatar
KNicholas2
Default '77 Coupe has poor handling
My '77 'Vette coupe just does not handle well at freeway speeds. It "oversteers" and is "twitchy". Someone asked if the car "darts" and I would have to say no. I rebuilt and replace the front suspension. I have the wheels alligned to specs recommended on this forum. It still is no fun to drive at speeds over 50 mph.
The car does have over-wide tires - I can't justify spending alot of $$ for new tires as en experiment. Does anyone have ideas?
Thank you.
Kim Nicholas
Seattle
Old Oct 8, 2005 | 01:05 PM
Matt O's Avatar
Matt O
Thank you.
Kim Nicholas
Seattle
If it's anything like my 69 the Power Steering Control Valve, Steering Box or the coupler just ahead of the steering box could be the problem. Did you have any of this looked at? Also, what tire pressure do you run?
Old Oct 8, 2005 | 01:10 PM
BigBlockk's Avatar
BigBlockk
What is it doing that you don't like?
BigBlockk
Later.....
Old Oct 8, 2005 | 02:35 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That sounds like a power steering issue. My car did some of that, it turned out the problem was actually a worn-out rag joint, which would let the steering move around a bit while the wheel remained steady. Check over your whole steering system, or have a competent shop do so.
Old Oct 8, 2005 | 02:41 PM
GTR1999's Avatar
GTR1999
Also check the rear suspension and diff yokes. I had completely worn yokes years ago and the car would shift going down the highway at 65 mph, I could feel the azz end move!
Gary
Old Oct 8, 2005 | 03:51 PM
mgcfst69's Avatar
mgcfst69
5th Gear
Had the same thing on my old 77, rebuilt front end and still when I went over a hill and the front end lifted any, it would become very unstable, I then replaced the idler arm, and then it drove like new again
Old Oct 8, 2005 | 10:18 PM
1mpalss's Avatar
1mpalss
My '70 showed similar symptoms until I put new wheels and tires on. The car drives pretty sweet now, compared to before. I replaced some very dated Mickey Thompson Indy Profiles with 335/35/17's in back and 255/45/17 up front, all mounted on ZR1 style wheels. I really didn't expect the improvement in ride and steering. The car used to be "scary-twitchy", for lack of a better description. It also bounced all over the place. Smooth as glass now compared to before. Just my 2 cents.
Old Oct 8, 2005 | 10:55 PM
PhotoVette1's Avatar
PhotoVette1
The '77 is one of the best handling, best balanced C3 there is. Just start replacing everything in the steering and suspension and you'll be amazed on how well it can do. And for not that much money either if you don't mind doing it yourself.
My '77 handles better than my Mits 3000GT VR4.
Old Oct 9, 2005 | 10:04 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by PhotoVette1
. ......My '77 handles better than my Mits 3000GT VR4.
well i like my 77 also and i put in the steeroids set up but i wouldn't go this far.
Old Oct 12, 2005 | 11:55 AM
KNicholas2's Avatar
KNicholas2
Default I have tried most of these...
Thanks to all that replied with suggestions. I HAVE replaced the idler arms, the front bushings, the ball joints, the fiber couple, the power steering control valve and probably other stuff I can;t think of. I have not changed the steering box or tires. Do I need to address these?
Kim Nicholas
Old Oct 12, 2005 | 12:38 PM
GUSTO14's Avatar
GUSTO14
Have you had the alignment checked? With exceptionally wide tires on the front sometimes a good alignment can help. Toe is very critical when you run very wide tires on the front.
We put 225/50's on my son's Toyota Tacoma from original 205/70's and the front became much more twitchy unless on the smoothest of roads. In the winter we replace them with the originals and it tracks well again.
Good luck... GUSTO
Old Oct 12, 2005 | 05:48 PM
C3nMe's Avatar
C3nMe
These posts have given me a few ideas of things I should check out in my steering setup ...as my car tends to "drift", but it's something that I attributed to the tendencies of a non-rack type steering. The tires on my '77 are at pressure, but they are slightly wider than stock (I think), but they are the same all around.
Is the steering with the cylinder on the Vette's more "solid" than the typical 70's recirc ball type?
Is it just me, or is the cap on the power steering fluid tank in a freakin' impossible place to check the level?
Brian.
Old Oct 12, 2005 | 07:42 PM
neoh77's Avatar
neoh77
Brian.
Yes it should be very solid. Mine feels good at any speed and it's pretty original (55k miles). At about 90mph it feels more planted then at 65. I don't go much faster than that though. Everyone who drives it is surprised at how good the ride is and how solid the steering is although they almost always oversteer going down the road.
Yes it's impossible depending on what belt you have on there etc. Mine is impossible. i just loosen the alternator. Someday I'll get a shorter belt.
-Matt
Old Oct 12, 2005 | 07:53 PM
DollaGreen's Avatar
DollaGreen
There is a spring you can change out in the power steering control valve that gives it more feel. I was about to do this when told to try more Caster. It worked great. Not only did it fix the problem you discribe, but it made the feel and wheel return better at lower speeds as well.
To '77 Coupe has poor handling
