No Headlights
Old Oct 12, 2005 | 03:26 PM
IRISHMAFIA's Avatar
IRISHMAFIA
Navigator
Default No Headlights
1982 collectors, Lids Work...changed Headlight Switch...bulbs Ok..no Brights Or Dims..switch is on turn signal.....would it be bad?? any Suggestions ????my Wife Gives Me The Obvious Solution.."just Drive It In The Daytime!!!!!"...
Old Oct 12, 2005 | 03:29 PM
WhichVette?'s Avatar
WhichVette?
floor switch
Yeah, now that you added that it's an 82, I look like a retard. hah
I'm used to it, though...
big_G's Avatar
big_G
Check the hi-beam dimmer switch....
Old Oct 13, 2005 | 06:10 AM
IRISHMAFIA's Avatar
IRISHMAFIA
Navigator
Default daaa
Originally Posted by WhichVette?
floor switch
thanks for the help anyway , sorry for the confusion
Old Oct 13, 2005 | 08:05 PM
aqua80's Avatar
aqua80
Fusible link located in the harness for the starter motor. there are two links and one is specifically for the headlights.
Scott
Old Oct 13, 2005 | 09:31 PM
REDRED62's Avatar
REDRED62
I ran in to this one time. I changed a driver dash pad (and installed a new headlamp switch) for a customer. He went home and the next day before he went to work he changed a headlamp bulb. When he changed the bulb and pulled the bulb connector of the back, he broke the wire! This wire is a jumper wire that also feeds the back side of the headlamps.
So, while dumb me... Thinking the switch was bad, I pulled the pad and replaced it again with no results.
Check the wire connector behind the left hand hi beam headlamp bulb, if it's broken it will not feed current to the passenger side of the car.
To No Headlights
