Spreader bar
Old Oct 12, 2005 | 09:26 PM
70 LS1's Avatar
70 LS1
Default Spreader bar
Why are all the spreader bars adjustable? Wouldn't it be simpler and cheaper to make a solid one than one with heim joints? I think I am going to make a solid one unless someone can give me a good reason why not. Seems like all the Camaro and Mustang shock tower braces are solid. Same idea, right?
Old Oct 12, 2005 | 09:29 PM
big_G's Avatar
big_G
Adjustable 'cuz each frame is a little different.....
Old Oct 12, 2005 | 10:10 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
I'm thinking they're seeing a lot of forces that don't act down the shaft. In a solid brace, it might buckle something, probably the frame. With heim joints, it'll take an axial load but will keep parts from breaking when flexed in another direction.
Old Oct 12, 2005 | 10:19 PM
70 LS1's Avatar
70 LS1
I thought the whole point was to prevent flexing completely.
Old Oct 12, 2005 | 10:29 PM
Buffalo Dude
St. Jude Donor '07
Yes, but in a specific direction (axially along the spreader bar). If it were solid mounts, it might be more prone to bending the mounts and because they're attached to the A-arms, it might bend them. It can only be as strong as its weakest link. The idea is to transfer load and minimize flexing of the frame along the bar, which it does well. Forces perpendicular to a solid mount bar now have a giant moment arm (the spreader bar) that can tweak the A-arm mounts out of whack. It might be a different issue with shock towers.
Old Oct 12, 2005 | 10:38 PM
big_G's Avatar
big_G
The Corvette frame has a weakness in that the tops of the shock/spring towers creep togeather gradually over the years. This can be seen when doing a wheel alignment, and there is insufficient adjustment for camber, hence the need for off-set upper shafts. I believe the only loads distributed to the spreader bar are compression.
Old Oct 12, 2005 | 10:50 PM
aqua80's Avatar
aqua80
Originally Posted by big_G
This can be seen when doing a wheel alignment.
This is the opperable phase. The spreader bar sits against the upper cross shafts that most likely will be moved slightly (via shimming) at each alignment. There fore make your bar adjustable.
Scott
Old Oct 13, 2005 | 09:02 AM
norvalwilhelm's Avatar
norvalwilhelm
It is but without adjustability how do you preload the suspension/frame. All frames are not exactly alike and if you system mounts over the existing A arm studs who do you account for adding shims to the arm for caster/camber adjustment.
If you have a fixed bar and you want to add a 1/8th shim for alignment purposes how does the bar accomodate it.
Rod ends in 5/8th from Coleman for the bar are about $8-$10. Two of them won't break you and a bar in the 16-20 inch length is about $12.00 YOU just have to make the brackets.
Old Oct 13, 2005 | 09:05 AM
norvalwilhelm
This is from a post I did about 2 weeks ago
I finally got around to building a spreader bar. I had a special problem because of the 3 inch blower belt. I had to pull the rad and support to get in there for welding
I ended up making brackets from angle iron that slid over the A arm studs and didn’t have to weld on the car at all.
This is one of the brackets after powder coating.
My car is black, everything is black so things don’t show up that well.
For the cross bar I used 1 inch solid aluminum hex and turned the center down for appearance and left the hex at the ends for a wrench.
I used 5/8th rod ends, one left on the left side of the car and one right with locking nuts.
The bar is only 16 inches long. It is strickly bolt on and required no on car welding.
Old Oct 13, 2005 | 09:30 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
The real reason is that the spreader bars sits on the A-Arm over the A-Arm bolts. Without the heim joints how can you adjust the Camber / caster??
You NEED to be able to back it off, reshim, adjust the spreader, measure the camber and repete. Also with caster the A-Arm will not be perpendicular to the spreader, hence the Heim joits. The issue with Norvals design is since the bar is not between the A-Arm bolts he will have to tighen the A-Arm bolt between each adjustment, When the bar is between the bolts you just have to preload the spreader after each adjustment.
Now if you welded a mount to the shock tower it's work great and not need to be adjustable. but most people do't want to weld to their car.
Old Oct 13, 2005 | 11:16 AM
68/70Vette's Avatar
68/70Vette
A C2 acquaintance of mine claims he had this problem. He ran out of camber adjustment and had to have a frame shop push the spring towers into their original position. He said the shop used torches to heat the frame crossmember (just below the crank damper) to make bending the frame easier.
Old Oct 13, 2005 | 11:07 PM
70 LS1's Avatar
70 LS1
So how far apart should the A-arm mounts be?
Old Oct 14, 2005 | 07:51 AM
norvalwilhelm
If you are making you own spreader bar make them anything you want then just order a bar that suits your application. Get the rod ends first before going with the bar. They do take alot of room themselves.
I find Coleman has all the parts in stock.
Old Oct 14, 2005 | 10:25 AM
Wrencher's Avatar
Wrencher
That is what I did. With my BB, I made two stainless "U" brackets that bolted to each front A-arm stud, then manufactured my own adjustable bar. I didn't "pre-load" mine, just tight with the car straight and level on the ground. However, on a BB it does prevent the use of a stock fan.
Total cost was about $40.00.
Hans
Old Oct 14, 2005 | 03:23 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Should be 26 3/8". Measure just in front of the front bolt that goes through the upper a-arms. Measure from frame to frame. If you call me up I can fax you you frame specs.
Dan
To Spreader bar
