Engine Won't Stay On (Help)
Old Oct 16, 2005 | 10:39 AM
KenSny's Avatar
KenSny
A couple of years ago I was having timing problems and the Qjet that was on the car when I got it was not providing the correct vacuum at the right ports. I sent it to Lars for him to work on. I also got his info on the distributor because my timing was never stable. I took my HEI out and cleaned the gunk off the weights replaced the springs, etc. But the main thing was the amount of slop in the shaft/gear. I re-shimmed the drive gear end-play from 0.059" to 0.004", spec is 0.002"-0.007" and it made a world of difference.
Old Oct 16, 2005 | 07:30 PM
enkeivette's Avatar
enkeivette
OK, sorry it took so long. Open this and let it load in the background for a few minutes before you watch it. ->Stroker Test Drive
