Overheats when ideling
Greetings, I'll try not to sound too dumbfounded as I am a newbie!
I recently purchased a 69 base model 350/300 vette just about completely restored. I am having problems with it overheating when going under about 30mph or ideling, temps running 230-245+. At highway speeds temps is fine, typically temps 180-200. I have receipts (and know the guy well) from whom I boiught it from and it has a brand new radiator, temp sender, thermostat (180), water pump, and fan shroud. A thermometer verifys the temp, so it's not the display guage.
Intristingly, when it gets real hot, if I rev the engine for 30 sec or so the temp drops. Someone suggested if that happens the impellers in the water pump could be bad, but the water pump was replaced?
Any ideas??????Help please-
Andy
Andy
I did forget to mention the fan clutch, That was suspected, thought to be bad and replaced.
Not too sure about the foam seal around the radiator, is that basically just a seal adjoining/between the shroud and the radiator?
I really appreciate the suggestions!
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,939 Likes
Andy -
The most common reason I see for low-rpm/low speed overheating is incorrect timing and timing advance. Before you start working on the cooling system, make sure you are set up right:
Set your timing for 36 degrees total (which will get you somewhere around 12 to 20 degrees initial) and make darned sure your vacuum advance control unit is functional: many are ruptured and defective. Replace it if it is not working. Hook the vacuum advance up to a direct manifold vacuum source (not ported) to pull the full advance in at idle. With this hooked up, you should see about 28-34 degrees of timing at idle and low rpm.
Inadequate timing increases engine temp drastically.
Received 1,470 Likes
Cruise-In II Veteran
1 Post
Cruise-In I Veteran
Andy
Andy
