79 Vett needs 17" wheels
Old Oct 17, 2005 | 11:37 AM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
Default 79 Vett needs 17" wheels
I have a highly modified 79 vette with VBP complete suspension kit with off set rear trailing arms, spredder ber in front etc. I want to install 17 x9 rear and 17x8 wheels. Has any one done this and do you have a wheel manufacturer I can buy from?
Old Oct 17, 2005 | 12:12 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
That combo will work just fine. For the fronts you need a 4" backspacing and for the rear you need a 5" backspacing. Wheel manufacture will depend on what you like. There are a million different wheel manufactures. You just have to make sure they can do this type of backspacing for you.
Weld Racing
American Racing
Crager
Boyd Coddington
A few common companies
Old Oct 17, 2005 | 12:19 PM
Gordonm's Avatar
Gordonm
I have 17X8 on all four corners with a 4 inch backspacing. As was already said there are a lot of different styles to choose from. Mine are AR TTIIs running 255 45 17s on all four corners.
Old Oct 17, 2005 | 04:27 PM
69Myway's Avatar
69Myway
Check out Intro wheels at www.hvydeez.com
Dave knows Corvettes well and can get a perfect fit for you.
You might want to consider 18" however. I think they look much better and are now the common size wheel on any performance car. Tires are much more affordable now and you have a wider selection of choices.
Old Oct 17, 2005 | 04:41 PM
74droptop's Avatar
74droptop
FYI
I run 17x9.5 at all four corners with 285/40/17 tires they have a 5"
back space and no rubbing anywhere, these are Centerline wheels.
Old Oct 17, 2005 | 05:18 PM
gkull's Avatar
gkull
my 79 has had 9 and 11 X 17 for 6-7 years. My advice is 18 rear and maybe 17 front because you can't get enough tire diameter in the wider rear tires like the 315 and 325.
Modified Vettes have real traction problems without big sticky tires.
Old Oct 17, 2005 | 05:29 PM
Jay M's Avatar
Jay M
What is the widest practical tire for the front?
I have 245/17 now, but they arent quite enough. They took a real beating at the track.
~Jay
Old Oct 17, 2005 | 05:52 PM
Bimmervet's Avatar
Bimmervet
I like the way your car is set up, however my car is about 2" lower than stock. I have Progressive 9X15 on all four with 265x50 front and 305x50 Euro TA . The tires are 8 years old look new but are worthless. I have not run an auto cross in 4 years. Last time took FTD out of 62 Corvettes. Since then I dropped in a built 355 small block with about 412 hp added the spredder bar and new shocks, and new built turbo 350.
I want to run auto cross and track events in 2006. That is why I want 17" wheels.
Old Oct 17, 2005 | 06:56 PM
77 vette's Avatar
77 vette
I've got the Van Steel's double off set t/a's with a 2" VP&B shorter composite rear spring on my 77, It's lowered to 26.5 and has a real nice stance, I installed Torq Thrust 11 polished wheels that measure 9.5x17 rear with 5" back spacing and 8x17 front with 4" backspacing, they fit and look great with no problems, I've got 275's in the back that could easly fit a 285 and maybe 295's, the outboard surface of the tire aligns with the stock fender/flair's edge with the rest of the tire tucked into the well, these tires are some what rounded at the edge so I would have to hit a BIG hole to damage my fenders (not going to happen). My plan is to install the 383, thrash the tires and go bigger . When I go bigger I might have to trim about half of the inner fenders edges at the top only to gain tire clearance.
Old Oct 18, 2005 | 02:30 AM
stickboy's Avatar
stickboy
As stated above there are lots of options. One thing I didn't see mentioned is you need to make sure the wheels will clear the calipers. The caliper on our vette are wider than most cars and I have read of some people that got wheels that hit them.
Old Oct 18, 2005 | 10:50 AM
CGGorman's Avatar
CGGorman
Cragar S/S hit the caliper. The similar-looking American Racing T.T. II's do not.
Old Oct 18, 2005 | 03:16 PM
gkull's Avatar
gkull
~Jay
I used 275 fronts on Centerline 9.5/17 with 4 BS.
Your front tires should not be getting beat up if you use correct alignment. Have it set for Zero toe neg .75 camber and as much castor as they can. My 79 is set for 3.94 and never looses shims.
To 79 Vett needs 17" wheels
