Setting rear camber
Setting rear camber
I have seen all the guides written on the subject of rear end alignment. I see the notches on the camber adjusting bolts, some one said that they were 1 degree marks. But what do these marks line up with. Are they just relative markings? I have my strut rods off now, new bushings along with rebuilt bearings, and I would like to reassemble as close to the 0 degree camber mark as possible. Is this even possible, or will I have to go through the process of setting the camber after I reinstall it all. I would like to get it as close to 0 without having to do to much work so I can drive it over to an alignment shop and get computerized measurements done and dial them in at the shop.
The marks are relative, just set the wheels for maybe 3* positive camber off the ground (unless you have "Smart-Struts"). Roll vehicle on the ground about 10 feet and re-check camber visually. Re-adjust as necessary. If using Smart-Struts, adjust for 0* off the ground .G/L
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,938 Likes
If you just want to get it close enough to get to the alignment shop, you can just eye-ball the camber - camber won't kill your tires, even if it's WAY off. It's toe that will destroy the tires: Get the toe as close as you can with a tape measure - within 1/8". If toe is way off, it will destroy a set of tires in no time.
Originally Posted by PEPresnell
with the car on the floor, use a carpenters level and set the wheels stright up and down, this will get you to the shop
