Crate motor?
I was hoping that somebody on here could lead me in the right direction as to what all would be required. Any unforseen issues? Who have you bought yours from? Is it possible to do this swap under $2500?
Thanks!
I have a 71' Coupe, and put a ZZ4 stock with 355hp, but upgraded to the port and polished heads and roller rockers, 390hp.
Delivered to my door was 5400.00
Not cheap, but woth it to me , as I am doing a frame off.
They have a 290 hp for around 2800.. If I remember correctly.
Later,
Jw
Later,
Jw
I have 4 grand into my motor and i make 470 hp.
I was thinking this may be the route I can take. If I were to get the package with the new carb and ignition would I have any issuses? Is the stock quadrajet hooked up to a computer in any way? I am wanting something that is basically 'install and go.' Any other advice is appreciated! THANKS!
330hp 350 HO for $2,330
Votec heads, so you would need a different intake.
Here, I'll just copy the details...
Our lowest priced crate engine, the 330 horsepower 350 HO doesn't sacrifice power or durability, it just pumps up the value. With its four bolt main block, nodular iron crankshaft, PM steel connecting rods and light but strong cast aluminum pistons, this engine screams durability. Add to the strong foundation a pair of 64cc Vortec cast iron cylinder heads and a dual pattern camshaft with just a bit of a "lumpy" idle, and you've got the muscle car small block that you've been looking for. Dressed to impress with chrome valve covers and timing cover, this engine will look great between the fenders of your favorite street rod, muscle car or grass roots racer. The cylinder heads on this great little performer use 1.94" intake and 1.50" exhaust valves that are sprung with 1999 Corvette L3I valve springs. The 64cc chambers yield a healthy, but streetable 9.1 to 1 compression ratio. The cam is a modern dual pattern interpretation of the old '65 to '67 Corvette 327 cam. But with more lift and duration on the exhaust side, it does a better job of clearing exhaust from the combustion chamber. We also decreased duration and lift ever so slightly on the intake side to build more cylinder pressure. The result is a cam that makes great torque and horsepower with the 350 HO's 9.1 to 1 compression ratio. Add the new dual plane intake manifold P/N 12496820, 650 cfm carburetor, HEI distributor, torsional damper, water pump and exhaust manifolds or headers and you've got an outstanding muscle motor with a broad, smooth torque curve and an honest 330 horsepower. This manifold has four bolts, not six, to attach it to the cylinder head. Older six-bolt manifolds will not fit the new Vortec heads. The 350 HO is not intended for marine use, and should only be used in 1975 and earlier pre-emissions street vehicles or any year off road vehicles.
This would work: Edelbrock Performer Vortec Intake Manifold - Runs about $170.
They also suggested that you use a 650 cfm carb. Edelbrock carries one for about $375. Maybe someone else could answer the question about using a stock carb. I really don't know.
