355 Build
Old Oct 18, 2005 | 09:14 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default 355 Build
Help me build my 355 specs
Block 350 bored over .30
Vortec Heads
Vortec Weiand Intake
Holley 770 Cfm Street Avanger
10:1-10.5:1 Compression
Need help on choosing a cam i would like to keep the factory stall if possible but do not want anything over 3000 stall
This is going to be a street car.
I have been looking at the lunati cams I am thinking about going with the voodoo serires but need help on choosing.
Old Oct 18, 2005 | 11:00 PM
L-82kid's Avatar
L-82kid
Have you thought about getting a hyd. roller cam? You won't have to worry about breaking it in or wiping lobes. Plus they're good for making power on the street.
Old Oct 18, 2005 | 11:13 PM
ltlevil's Avatar
ltlevil
If you already have everything and know exactly what you want to do with the car, call the manufacturer. Talk with them and give them your information. I am partial to Erson cams for this very reason. You can have a cam ground for your engine for a few dollars more if any. Off the shelf cams are generic and made to fit the in between of a lot of different set-ups. There are several off the shelf cams that work well with different engine combos, but talk to the people that make them they are the ones who designed the cams in the first place. If you aren't comfortable with what one of them tells you or feel they don't know what they are talking about then shop around, it's your engine and money. JMHO.
ltlevil
Old Oct 19, 2005 | 06:17 PM
chewy's Avatar
chewy
Have the guides been modfied for more lift? I built pretty much the same combo with less compression and a Q-jet. Used an XE-256 with a 4sp and 3.08s it works super. I would recommend much more cam with your compression if the heads can stand the lift.
Old Oct 20, 2005 | 12:44 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Single pattern < 270* full duration.
Vortec Heads
Isky Mega with 108* LSA and 270* or less duration.
Comp Magnum with 110* LSA and 270* duration.
1.6 ratio rockers too.
Keep ur stock stall but should reduce compression to 9.0:1-9.5:1 with those iron heads - yes dished pistons. If u want higher compression then it gets complicated fast - dual pattern cam(s), more duration/overlap, more lift/better vlv springs, higher stall conveter.
Don't know a thing 'bout voodoo cams so good luck.
cardo0
Old Oct 20, 2005 | 11:00 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
why do you want a compression ratio that high? how much horse power/torque are you trying to build?
Old Oct 20, 2005 | 11:07 AM
lars's Avatar
lars
For a street car, limit the comp ratio to 10:1 (9.5 may be safer) and put a real carb on it.
To 355 Build
