C3 Headlight Problem
Old Oct 19, 2005 | 09:43 AM
Zetol's Avatar
Zetol
8th Gear
Default C3 Headlight Problem
I just encountered a problem on my 79 that really has me stumped. Everything with the lights has been fine and I switched to high beam last night and both lights went out. Does anyone know what would make both of my headlights go out when I switch to high beam?
Old Oct 19, 2005 | 09:45 AM
big_G's Avatar
big_G
The high beam switch may be defective.
Old Oct 19, 2005 | 10:23 AM
CraigandJanet's Avatar
CraigandJanet
Check the relay. Also, you didn't mention if both high and low are out, or just high. Distant as it may seem, check the bulbs. I once had both lows go out at almost the same time. Ended up being the filaments just coordinated their demise. High beams aren't used as much and usually go into the trash in working condition with their low beam cousins.
Old Oct 19, 2005 | 12:57 PM
Zetol's Avatar
Zetol
8th Gear
CraigandJanet it is only the high beams, I had the low beams on and switched to high and both headlights went out.
Old Oct 19, 2005 | 01:18 PM
CraigandJanet
Ok. I'll look at mine, and at the schematic for yours when I get home tonight, and see if we can work out a logical troubleshooting routine. Shouldn't be hard to find.
Old Oct 19, 2005 | 06:19 PM
CraigandJanet
Looks like Big G got it right the first time by suspecting the dimmer switch. My wiring diagram doesn't show any relay. Power comes from the LIGHT SWITCH to the DIMMER on a Yellow wire, then splits at the DIMMER to a Tan wire (Low Beam) and a Light Green wire (Hi Beam and Hi Beam Indicator). Ground is common to both Hi and Low, so that's eliminated as a problem since Low Beam works. The only circuit breaker in the system is before the LIGHT SWITCH. The switch isn't fun, so before you do anything, unplug the headlights at the bulb and run a continuity check on each filament. Both the Hi Beams may be out. Stranger things have happened, and one of the Hi Beams may have already been out for a while and you didn't realize it. Let us know...
Old Oct 19, 2005 | 07:10 PM
Zetol's Avatar
Zetol
8th Gear
Gee, I can't tell you how much I appreciate this, thanks! I will post the results. Thanks again!!
Old Oct 19, 2005 | 07:13 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
this is stuff on an 80, but should be pretty close - click for link
The guy did one hell of a job...
Old Oct 21, 2005 | 10:59 PM
vette64772's Avatar
vette64772
My 77 did the same thing a while back. Turns out that the rod that switches the switch, was bent. Only switched the low beams off, didn't complete the transition to high. There is also room for play if the switch itself becomes loos where it is mounted. Straighten the rod and secure the switch!
Old Oct 21, 2005 | 11:08 PM
enkeivette's Avatar
enkeivette
Same thing happened to me recently, don't forgot to post the results! I'm curious to know.
Old Oct 22, 2005 | 01:04 AM
Fubba's Avatar
Fubba
Same thing happened to me. Was the dimmer switch. It was in the middle of the night on a unlit backroad. Hit the switch, the lights flickered then died. I just had to guess where the shoulder was. I fiddled and fiddled in the dark, because stupid me, i didn't have my flashlight in there. Got them to come on, but they would only stay on bright. Needless to say, I got a lot of lights flashed at me that night. You gotta do what you gotta do.
Old Oct 22, 2005 | 06:00 AM
enkeivette's Avatar
enkeivette
Wow, awesome. I just drove home at 2:30am with no headlights. Normally I can jiggle the high beam lever and get it to work, but not tonight.
I'm almost positive it's my high beam switch. How hard is it to get to? Does the steering column need to be disassembled somehow?!
Old Oct 22, 2005 | 06:04 AM
PhotoVette1's Avatar
PhotoVette1
Could be the circuit breaker for the headlights is weak--or there is a real short in the high beam circuit.
Old Nov 5, 2005 | 07:31 PM
Zetol's Avatar
Zetol
8th Gear
Default C3 Headlight problem
Hey guys,
Thanks for all the information to troubleshoot this!! It turned out to be a loose connection at the right headlight, it took out both hi-beam lights. Couldn't have found it without your help, I really appreciate all of you!
Z
To C3 Headlight Problem
