Does this look right?
Old Oct 22, 2005 | 12:34 AM
matthud's Avatar
matthud
Default Does this look right?
Can someone tell me if the bushings and the mounting for my rear spring look correct. To me it doesn't look right, other than the rubber being bad. The bolts seem to angle rearwards quite a way. From what I've seen in other's setups these bolts look very vertical. Also is that stacking of bushings correct?
Old Oct 22, 2005 | 01:35 AM
tracdogg2's Avatar
tracdogg2
With the shock loose the trailing arm is down lower increasing the angle of the spring bolt. The stacking of the bushings is bad. You need a new spring.
Mike
Old Oct 22, 2005 | 07:16 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
My bolts swing like that too. Can't see the bushings all that well to comment on the stacking.
Old Oct 22, 2005 | 08:40 AM
w1ctc's Avatar
w1ctc
Extra bushing seem to be added to raze the rear or compensate for a weak spring.
Old Oct 22, 2005 | 08:45 AM
moosie982's Avatar
moosie982
Hi, At ride height,, car on the ground ready to go with the spring "settled" the bolt should be almost vertical, at least thats the way mine are. Peace,,, Moosie
Old Oct 22, 2005 | 02:23 PM
matthud's Avatar
matthud
Thats what I was afraid of. Its never looked right to me and now that people have confirmed it I might have to look into a new spring.
Old Oct 23, 2005 | 11:52 PM
matthud's Avatar
matthud
Here is a picture of my car at ride height. Does it look like it is high/low? I am trying to figure out if I can take the extra spring cushions out without dropping the ride height too far down.
Old Oct 23, 2005 | 11:57 PM
ThereIsNoSpoon's Avatar
ThereIsNoSpoon
Nice looking car. It's a little hard to tell at that angle, but it looks like it could go lower.
Old Oct 24, 2005 | 08:19 AM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
when i get home in a few hours i will take a picture of my rear spring ends for you sense my car is up on stands right now that way you can have something to compair to.
Old Oct 24, 2005 | 10:50 AM
matthud's Avatar
matthud
Here is a different picture of my car to check ride height. It may look like it is on an angle but that was just how the picture is taken.
From this picture, does anyone recommend that I lower my rear ride height, by removing the extra spring cushions talked about above.
Old Oct 24, 2005 | 11:27 AM
Garys 68's Avatar
Garys 68
I've seen other stock vettes with about that ride height.
If you lower the rear by removing a bushing, the front might look too high. That's a lot mor work to change the front ride height. I suspect an old rear spring is why someone added the bushing to keep the rear even with the front.
Gary
Old Oct 24, 2005 | 11:28 AM
TedH's Avatar
TedH
Your car looks high in the rear. Try installing the bushings correctly and perhaps adjust the spring cushion bolts. I'll check my Vette Brakes catalog but recall ride height (to lip of your fender) should be in neighborhood of 26.5"-27" (will verify after my 10:30am CT meeting). If it adjusts correctly, I'd say no spring replacement needed unless there is spring damage.
To Does this look right?
