bent fuel pump rod
Old Oct 26, 2005 | 06:21 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Default bent fuel pump rod
well i ws cleaning up the garage and giving away old engine parts, etc and i came across the fuel pump rod from my old L48 and as i was looking at it i realized that it was actually bent....somethng like the last 1 1/2" or so was noticeably bent???? wonder what casued that?
Old Oct 26, 2005 | 06:49 PM
enkeivette's Avatar
enkeivette
Unless it was just a ****ty rod and you made too much power for it, the only thing that I could think of would be improper installation.
I've heard about bent fuel pump pushrods before but I just can't imagine a fat rod like that getting bent. Show pics if you get around to it.
Old Oct 26, 2005 | 06:51 PM
chris75stingray's Avatar
chris75stingray
my uncle the " mechanic" bent one before. he tried to bolt in the fuel pump without pushing the rod back up in the engine. he kept cranking the bolts down and bent it. i ended up having to just put a block off plate on the engine and install and electric fuel pump. (the rod was jammed in the engine )
Old Oct 26, 2005 | 06:58 PM
enkeivette's Avatar
enkeivette
You think that's bad... my friend the 'Mechanic' installed my clutch backwards! That was fun pulling the trans the day after I had just put it in with the new engine! And if it wasn't for my literacy he would have also installed my distributor the wrong way.
Lesson learned, people love to be cocky but rarely do they know what they're doing.
To bent fuel pump rod
