Starting Problem
Old Oct 26, 2005 | 08:11 PM
82Powerhouse's Avatar
82Powerhouse
Default Starting Problem
1982
350 CID, Carb
I installed an electric fan, and today I had a wire smoke on me while I was driving. I pulled into a parking lot and turned off the engine. Once I disconnected the wire, I tried to start the engine, but it would not start. I checked the ignition switch and it had a burn on it, so I changed it out, but it was the same. I checked all of the fuses, but they were fine. I am getting power to the distributor while I am cranking, but once I turn the key back to “run” there is no power there. I hooked a wire straight from the battery to the distributor to see if that would make it start, but it did not make any difference. Any advice on this would be greatly appreciated.
TIA,
CDM
Old Oct 27, 2005 | 08:44 PM
Bass's Avatar
Bass
Is the car turning over? If not, check the fusable link at the starter.
Old Oct 27, 2005 | 11:07 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i agree, even if the car is turning over, check the fusible link it can go up into the wire loom several inches
Old Oct 27, 2005 | 11:40 PM
82Powerhouse
Default Starting Problem still
Yes. It does turn over and we do have spark. I will check that fuse and see what there is to see. It is directly at the starter?
To Starting Problem
