Need help locating electrical short please
Old Oct 27, 2005 | 12:44 PM
spinedoc's Avatar
spinedoc
Default Need help locating electrical short please
I have a 1980 vette. I inadvertantly shorted out some of the engine wiring harness hooking up the starter. I replaced just the burnt out wires and the car now starts and runs, and everything except the wipers seem to work. Now however, the battery in the car dies in a day or two. So I assume I have a short somewhere. Can someone help me locate it. I was told to pull one fuse at a time and see if one causes the battery to not die. That sounds good, but I would like to know if I could be more specific. I have a cheap meter, but I honestly don't know how to use it. I thought I would measure the battery, i am guessing it should be 12 volts charged, then pull a fuse and measure the battery again later on. Is this correct? What setting do I put the meter on, it has about 8 of them. I would appreciate any help with this.
Also can a drain on the battery, or a short cause the engine to run with less power?
Thanks,
Eric
Old Oct 27, 2005 | 01:09 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Eric,
Disconnect the on lead of the battery and charge it
Take your digital multi-meter and set it to read AMPS not volts
Connect the test leads to the meter as described in the meter's instructions to read AMPS
Connect one meter lead to the battery, the other meter lead to the disconnected battery cable
Any reading of more that a few milli-amps is a short to ground
Remove one fuse at a time and monitor the meter, when the current drain goes to zero, that circuit has the short.
IF the meter still displays a drain (short) my best guess is that you now have a short to ground in the alternator, take it to your FALPS and have it tested.
Old Oct 27, 2005 | 01:17 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Take a light bulb and hold it close to the wiring. Then move it around until it starts to light up. That's when you've found out where the electricity is escaping.
Seriously, I would focus on the area you damaged. When installing the starter wiring, did you accidentally cut through part or all of a section of the wiring harness? You say you replaced burned up wires which indicates more than accidentally slicing a couple wires. I'm assuming you checked all the fuses to make sure none were blown. If your problem area is the wipers, have you traces all of the wiring related to the wipers?
Which engine harness did you damage and physically where was it damaged? I can check my schematic for you or I can run down and have a look at mine since it's here at work today.
Old Oct 27, 2005 | 01:32 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Just remember that the switch for the door is open so the courtesy lamp circut will show a short keep the door switch closed & the hood closed.
Old Oct 27, 2005 | 06:28 PM
LYLE's Avatar
LYLE
The ground to the wipers is easy to burn out with the starter wires wrong. Check by using a jumper ground and see if the wipers will work.
Old Oct 28, 2005 | 09:01 AM
spinedoc's Avatar
spinedoc
Thanks for all the help guys. I am going to read how to use the meter at lunch today, Friday, and start troubleshooting tonight or tomorrow.
The burned wires were in the engine harness and smoked wires all the way up to under the dash as well. I pulled the dash and swapped out all I could see that were burned.
Do I disconnect the positive or negative cable at the battery when I test, does it matter?
I will try to find the ground for the wipers to see if that solves the wiper problem.
Also, will a drain on the battery like this decrease my engine power in any way?
thanks,
eric
Old Oct 28, 2005 | 10:59 AM
68/70Vette's Avatar
68/70Vette
And make sure the little light in the storage compartment is not on. That was the cause of one of my dead battery incidents.
Old Oct 28, 2005 | 11:04 AM
68/70Vette's Avatar
68/70Vette
Also, after doing electrical work on the car, particularly when you've done some substantial mods, etc, you don't have to....and I don't think you should....power up the car with the big lead battery. If there's a short it can put out hundreds of amperes and really fry and vaporize things. Why not buy two 6 volt lantern batteries, wire them in series for 12 volts total, and then connect them to the cars electrical system? If there's a inadvertent short they won't put out as much current. (The best more expensive option is to use a current limited 12 volt power supply.)
Old Oct 28, 2005 | 12:36 PM
LYLE's Avatar
LYLE
The ground for the wipers is spliced inside the wraped engine harness near the wiper motor.
Old Oct 28, 2005 | 12:44 PM
71redskin's Avatar
71redskin
i had a short that was driving me crazy too... bought multi meters and the whole nine... finally found out the pos cable from the battery had welded itself to the exhaust manifold...something you might wanna check
Old Oct 28, 2005 | 03:48 PM
theandies's Avatar
theandies
The ground for the wiper motor travels down the engine wiring harness to the starter side of the engine. It is usually connected to the blower motor ground point. To test you wipers and you think it is a wiper motor ground, all you have to do is take a piece of wire and ground the outside case of the motor to any grounded surface.
Old Oct 31, 2005 | 08:02 PM
spinedoc's Avatar
spinedoc
Well I tried to use the amps setting, but I think I have a cheap meter and it is giving me confusing results. I am going to try to get a better one from a friend tomorrow.
Grounding the wiper motor didn't get them going, So I will look elsewhere for the culprit.
Also, I noticed a lot of other unconnected wires I hadn't noticed before, and some of them were hot . I am thinking if this doesn't work out, I may need a new wiring harness, not a job I want to do, but if I need to, where is a good supplier of harnesses for our cars?
I will continue working on this and keep you posted.
thanks,
Eric
Old Oct 31, 2005 | 08:09 PM
indy99's Avatar
indy99
From: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
If you need a new harness try these folks. http://www.lectriclimited.com/corvette_catalog.htm They carry a great selection and are pre tested.
Good luck DB
Old Oct 31, 2005 | 09:58 PM
Sprzout's Avatar
Sprzout
Just a thought:
If your battery is draining after a day or so, check your alternator and wiring to your alternator as well; the short might have extended out there and deep-fried it.
I actually had a similar problem in an old Saturn of mine; the alternator died and I drove my car down from Orange County to San Diego, running on nothing but my battery. Fortunately it was during the day, so I didn't need any power for my headlights or anything draining like that, but when I got there the car died in the driveway and required an overnight battery charge for me to get it into the dealer.
To Need help locating electrical short please
