700R4 accumulator spring
Old Oct 27, 2005 | 06:42 PM
Pauls81's Avatar
Pauls81
Cruising
Default 700R4 accumulator spring
I've got a built 700R4 and the 1-2 shift is too firm. I want to change to a softer 1-2 accumulator spring. I found a place that sells the springs, but I don't know which one I need. They have a white, violet, red, orange and green. Which one is the softest shift? Thanks!
Old Oct 27, 2005 | 11:12 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
are you sure the TV cable is set up correctly? i'm using the BTO TV cam set up and i can control that pretty easily
Old Oct 28, 2005 | 10:40 AM
Pauls81's Avatar
Pauls81
Cruising
Yeah, I've got the adjustable Lokar TV cable. The trans is a TCI truckmaster series on my truck. The 1-2 shift is a little too firm and I'm afraid I will snap a u-joint since the truck is lifted with 4.10 gears, locker and 33" tires.
To 700R4 accumulator spring
