Shifting hard
Old Oct 29, 2005 | 05:35 PM
71Ttops's Avatar
71Ttops
6th Gear
Default Shifting hard
Yesterday I could shift smooth as silk and then today I have to push/pull the shifter harder and it feels like it's catching on something. I have a stock 4 speed and original clutch. Any ideas?
Old Oct 29, 2005 | 05:36 PM
Jclgodale3's Avatar
Jclgodale3
hows your fluid level?
Old Oct 29, 2005 | 05:37 PM
71Ttops's Avatar
71Ttops
6th Gear
The fluid level is just below the plug.
Old Oct 29, 2005 | 08:16 PM
zapp168's Avatar
zapp168
Is it harder to get into 1st or reverse from a standstill?
Old Oct 29, 2005 | 09:20 PM
big_G's Avatar
big_G
It sounds like the clutch may not be fully dis-engaging.
Old Oct 29, 2005 | 10:32 PM
Hwy St*r's Avatar
Hwy St*r
Where are you? In the Northeast it's getting colder here and the shifter requires a little more effort to pull through the gears.....
-Pete. KEEP DRIVING!!!
Old Nov 21, 2005 | 10:41 PM
71Ttops's Avatar
71Ttops
6th Gear
That's very possible because today the clutch just became a lot easier to press and I now have to hold it all the way down to the floor in order to start the car. Are these two problems related or should I be starting a new post?
Old Nov 21, 2005 | 10:51 PM
Drew's Avatar
Drew
Sounds like your clutch may be on the way out. When my clutch failed my car would only go into 4th gear, luckily I have 3:70 gears so I managed to limp the car home. Not too cool taking off in 4th gear LOL!...If your clutch is original like you say I'd replace it just for piece of mind.....Drew
Old Nov 21, 2005 | 11:39 PM
James B's Avatar
James B
I found that my transmission mount had worn out and my trans was sagging down low enough that the hurst shifter was hitting the cross member. I thought it was a linkage problem at first, but after driving long distances and my shifter getting VERY hot, I took a look. When it was shifted into third gear I could see the shifter hitting the crossmember which was conducting the heat from the exaust pipes through the shifter. I replaced the trans mount for 4.99 and it was good to go. Good luck finding your problem
James
Old Nov 22, 2005 | 10:07 AM
jimvette999's Avatar
jimvette999
Clutch may be fine...check master/slave operation first. Have someone press clutch pedal and watch to see if getting full travel. Pressure plate may have a broken spring. Release bearing could be hanging up on bearing retainer. Clutches slip, usually in a higher gear when accelerating when they're worn out......opposite of not releasing. Colder weather may be having a negative effect on the rubber cups in master/slave causing pressure loss. Any leaking hydraulic fluid?
To Shifting hard
