80 corvette exhaust question, weird.
Old Oct 30, 2005 | 09:22 AM
Sixminuteabs's Avatar
Sixminuteabs
Default 80 corvette exhaust question, weird.
I have a stock exhaust, 2-1-2. Stock L-48 engine. With the car running, I go behind and feel the exhaust. The passenger side is super hot and the driver side is way less hot. I have a test pipe installed so the converter is out. Still, it feeds the same left right rear mufflers. Shouldn't they be the same temperature?
Thanks,
6
Old Oct 30, 2005 | 10:42 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
This is odd enough that I'm going to go and check. Posting here to hold the spot.
I don't have a thermometer to verify, but I couldn't tell the difference from side to side, either in flow or in temperature. The guys below probably have it right. I'd guess a clog in the muffler.
When I cut up my old cat last year, you wouldn't believe the amount of accumulated crud in there. No reason for the mufflers to be any different.
Old Oct 30, 2005 | 10:50 AM
79VetteMike's Avatar
79VetteMike
I'd say that either one of your mufflers is clogged up or a pipe is pinched and most of your exhaust is coming out of one side.
Old Oct 30, 2005 | 10:59 AM
page62's Avatar
page62
Path of least resistance
Old Oct 30, 2005 | 03:52 PM
enkeivette's Avatar
enkeivette
I'm with page 62, the stock Y-Pipe flows into one side and has a pipe welded to the side of it for the other side.
Stick your head under there and examine it. Sounds like it's time for a new exhaust system if it bothers you.
To 80 corvette exhaust question, weird.
