Car running like crap...
Old Oct 30, 2005 | 05:20 PM
Stewart's74's Avatar
Stewart's74
Default Car running like crap...
2 weeks ago it was running absolutely perfect....in fact, its never ran better.
Now today, its like a different car. Hesitates, chugs, misses, exhaust pops....
At idle, when I rev the engine, it seems fine. In gear while cruising at 25mph, sounds like its missing. It kinda sputters. Upon heavy acceleration it misses big time.
I made sure all the plug wires were tight and swapped out the fuel filter. No change.
Could I have gotten some bad gas?
What else would cause this?
Old Oct 30, 2005 | 05:25 PM
LFZ's Avatar
LFZ
sounds like a vacuum leak
Old Oct 30, 2005 | 05:47 PM
marshrat99's Avatar
marshrat99
A vacuum is a possibility however if you've not done ANYTHING then a bad load of fuel could be the problem. If you've changed something then start looking there. Otherwise before starting to chase a vac problem, I'd dump some dry-gas into the tank and run it awhile. If this doesn't help then maybe start looking for a hose that's fallen off. What ever it is, I bet it is going to be something simple.
Old Oct 30, 2005 | 06:20 PM
Stewart's74
I havent made any changes to the car since Sept 24th.
Old Oct 30, 2005 | 06:27 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
and the last fill up was .....after the heavy rains???? has the car been inyour control could some have screwed with you at a parking lot.......my bet is bad gas
Old Oct 30, 2005 | 07:39 PM
Stewart's74
Actually Bob, my last fill-up was 2 or 3 months ago. So who knows. I doubt now that its bad gas.
I'm just pissed.
Old Oct 30, 2005 | 08:07 PM
jlaw68's Avatar
jlaw68
if its been 2 or 3 months ago, then that gas has gone bad. its was probaby fine when you filled up but over time it will go bad just from sitting. gas now just doesnt stay fresh like it used to.
Old Oct 30, 2005 | 11:30 PM
Vette Dent's Avatar
Vette Dent
Stewart, just plug the vacuum line coming off of the manifold. See what it does.
Old Oct 31, 2005 | 12:00 AM
PRNDL's Avatar
PRNDL
maybe lars spilled beer in it?
last time my vette took a sudden nosedive in performance one of my plug wires had fallen off... but you checked those already. I bet it's a hose off the carb. After all, the carb was off recently. agree that it should be something simple... hmmmm (thinking..............)
I just reread your post.... make sure distributor is snug (also recheck timing) could have been not tightened down properly and turned. Car would have run perfectly as you noted for a while, then a slightly loose hold down might have allowed the distributor to turn.
Old Oct 31, 2005 | 03:20 AM
keithkhd1's Avatar
keithkhd1
Enthusiast
Stu,
A longshot, but check to see if the battery fully charged. With an MSD if the battery / charging system drops below 9-10 volts it will exhibit symptoms like that before it stops running altogether.
Old Oct 31, 2005 | 05:29 AM
cosmicvette's Avatar
cosmicvette
my guess...BAD GAS.
My car had similar symptons to what you described,..it came on the boat from the USA so the gas was in the tank for 3 months or so. ...
anyway, I so didn't think BAD Gas would be causing what you described.......but I added some fresh gas and BAM! car was much much better.
Old Oct 31, 2005 | 05:58 AM
djgrelli's Avatar
djgrelli
I had the same problem last year. On the way to Ocean City it was running just fine. Then it started to run like crap. Especially on acceleration. I turned around and came home. Went crazy trying to find the problem. Went as far as replacing the Distributor with a new Mallory HEI. Still ran bad. My son suggested I change the spark plugs. and Knock on wood. It's been running great ever since. Who would have thought that the plugs went bad. I have had the same gas in my collector cars for months at a time. Just put a good stabilizer and some dry gas in it for the winter.
Old Oct 31, 2005 | 06:26 AM
73jst4fun's Avatar
73jst4fun
Sounds like gas to me Stewart, could be a clogged fuel filter, old plugs, or maybe cracked distributor cap, vacuum line......you'll find it...
Old Oct 31, 2005 | 09:21 AM
Stewart's74
Thanks for the input guys,
I checked the vac lines....they were all in place. I will re-check everything and report back.
I'm stumped...could I have a bad accell pump in the carb?
Old Oct 31, 2005 | 12:19 PM
Rich's'78's Avatar
Rich's'78
Gas won't 'go bad' that fast. I have had the same gas in my car for over 6 months without a problem.
Do you have complete control over the car? A friend of mine had the same simptoms and almost went nuts trying to find the cause (he is very knowledgeable) and finally found water in his tank. He leaves his car in the driveway and he figures a kid poured the water in because there was so much of it (about a quart I think). He found it by siphoning off the bottom of the tank. As you rev up under load the flow of gas picks up enough to sweep in the water.
Old Oct 31, 2005 | 01:11 PM
mvftw's Avatar
mvftw
Check your plugs... Maybe running rich & their black...
Old Oct 31, 2005 | 03:56 PM
corv58's Avatar
corv58
Default bad running engine
it does sound like the dist. has moved,or possibly bad gas....check with lars,maybe your check bounced and he recalled the tune-up,.....seriously keep us posted on what you found out. the info might be helpful to a lot of us....
To Car running like crap...
Old Oct 31, 2005 | 04:19 PM
Stewart's74
I'll throw a timing light on it and see if the thing moved. Pisses me off. I was bragging about how great its running.
Old Nov 1, 2005 | 05:18 PM
Stewart's74
I'm stumped.
The Dist does not appear to have moved, all vac lines are in place, plug wires are all secure.
Could it be the following:
1) Bad gas (still)
2) debris in carb jet
3) bad accel pump
4) coil related
As I said earlier, it seems to idle fine. The miss/skip/bog, whatever you want to call it, happened once while cruising at 25mph, upon heavy throttle, the car sputters badly and wont accelerate like it should.
Incidently, I filled it up w/93 octane as it was just below half full when the problems started. The problem persisted.
Any more ideas?
Old Nov 1, 2005 | 05:22 PM
1970-Bronze's Avatar
1970-Bronze
Any way to check your fuel pressure?
Maybe the pump is going bad.
