Car running like crap...
Old Nov 10, 2005 | 09:26 AM
  #41
Stewart's74's Avatar
Stewart's74
Originally Posted by bobs77vet
why not disconnect the fuel line and crank the car for a measured period of time and see what kind of flow you get out of the fuel line? actually measure it ...and then compare flow/time...
Bob, I'm a freekin HOBBIEST! I dont know squat about flow/time...It sounds like some sort of math problem to me....I hate math. I spent the better part of my college career trying to aviod math! I'll just spend the $30 and throw the old pump into the garbage. It's not shiny anymore so Imight as well swap it out...thats what real Hobbiests do...
Old Nov 10, 2005 | 10:20 AM
  #42
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
amen brother.....use a really long ratchet extension from the wheel well for one of the bolts and rememember there is a bolt in front of the engine that you can take out and put in a longer bolt to hold the fuel pump push rod in place
Old Nov 13, 2005 | 05:16 PM
  #43
Stewart's74
Looks like the Hobbiest fixed his car...without cutting a check!
I tried another coil, took for a road test and had the same problem. So it wasnt the coil.
Removed the plugs, they all looked good. No obvious problem.
Re checked dwell. It was right on 31. It hadnt changed.
I re-checked the secondary wind up spring. It seemed very loose. I adjusted it per Lars instructions. Took for another road test and the problem disappeared.
I'm guessing it was the wind up spring being too loose.
Either way, it runs like it should now.
VICTORY!
Old Nov 13, 2005 | 08:31 PM
  #44
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
I'm dealing with this same problem on my 80... Has an edelbrock thunder 650 with upgraded MSD Dist/MSD Coil and MSD Digital 6.
One of the earlier posts notes a member's car that ran fine while cold (so does mine!)...once warm it really hesitates under full throttle around 4000 and up RPM. Coil?
Also, the Edelbrock Thunder has a secondary spring loaded valve...could this be the issue...I haven't changed anything on this since it ran fine!
Thanks in advance for ANY help!
Running like crap in Texas...
Old Nov 13, 2005 | 10:26 PM
  #45
bobs77vet's Avatar
bobs77vet
good job!
Old Nov 14, 2005 | 05:47 PM
  #46
yellow71's Avatar
yellow71
OK I will ask the dumb question -
What is a "secondary wind up spring"?
Neil
Old Nov 14, 2005 | 07:36 PM
  #47
madmike's Avatar
madmike
i will second that motion... "secondary windup spring?"
Old Nov 14, 2005 | 09:02 PM
  #48
David Ey's Avatar
David Ey
It is the spring that goes into action after the primary windup spring has sprung.
Old Nov 15, 2005 | 12:25 AM
  #49
mpassmore3's Avatar
mpassmore3
3rd Gear
i once had a friend who had the same problems in another car, check the actual plug wires for a warn spot. possible you are grounding out a cylinder or two.
Old Nov 15, 2005 | 02:17 AM
  #50
Kalway's Avatar
Kalway
Damn... I'm too late to tell you to check the secondary windup spring. Yeah that's the problem.
(sarcasm for those with their detectors off)
Old Nov 15, 2005 | 09:55 AM
  #51
AGVI's Avatar
AGVI
Canadian Events Coordinator
VICTORY!
Good job Stew!!!
Old Nov 15, 2005 | 10:18 AM
  #52
lars's Avatar
lars
Neil
It's the adjustable windup spring for the secondary airvalve on a Q-Jet. Its adjustment is critical for proper tip-in of the secondaries since its tension determines the fuel shot the secondaries deliver upon opening (like a secondary accel pump). If the tension is inadequate, the car will fall on its face instantly upon secondary opening due to a lean-out condition.
Old Nov 15, 2005 | 10:21 PM
  #53
fcoppola's Avatar
fcoppola
Originally Posted by Brandywine
Whatever else is happening, it sounds like your plugs are fouled. Pull a plug, and you'll get more info about the problem. Anything unusual coming out the exhaust?
I would pull a few plugs.
Old Nov 16, 2005 | 10:29 AM
  #54
Stewart's74
Do you think anyone actually read ALL the posts in this thread??
Old Nov 16, 2005 | 11:03 AM
  #55
80TexasC3's Avatar
80TexasC3
I am... will continue to until I get mine running... Test the new coil tonight.
