Lars; I need your help on timing or anyone else
Old Oct 30, 2005 | 09:40 PM
brianlewis60's Avatar
brianlewis60
Default Lars; I need your help on timing or anyone else
1972 454 BBC bought it like it is but I can hear a pretty lumpy cam in it. also a turbo 400 tranny
here is my ?
Car seems to want so much timing that it will not start after a short ride. with the timing retarded where it will start every time then the car will not accelerate at all. spits and pops under any acceleration.
brand new HEI dist and new holley 770 street avenger. can anyone help where I can drive this car somewhere and have it run good there and start again?
Old Oct 30, 2005 | 10:27 PM
BigBlockk's Avatar
BigBlockk
Set the initial advance where the engine will start easy and hook the vacuum advance up to the manifold to get some throttle response out of it.
You may want to check all engine grounds and starter connections. Get some top cylinder cleaner to make sure it doesn't have carbon buildup.
BigBlockk
Later.....
Old Oct 30, 2005 | 10:35 PM
enkeivette's Avatar
enkeivette
Find out which cam is in it, then call the cam company and ask them for a timing spec for that cam.
Old Oct 31, 2005 | 09:17 AM
lars's Avatar
lars
Brian -
What timing specs are you set up to right now? If you can check your total timing, initial timing and tell me how much vacuum advance you're pulling in on top of that, I can see what the numbers indicate. Also: Are you running your vacuum advance off ported or manifold vacuum?
Another issue: That Street Avenger is a very lean-jetted carb, and it's extremely so for your application. This will produce some doggy performance. Once you get the timing curve taken care of, you might consider bumping the primary jetting on your carb up about 4 sizes and then jetting the secondary side so it's 8 sizes bigger than the primary.
Lars
Old Oct 31, 2005 | 04:03 PM
fugawi's Avatar
fugawi
all hail the great LARS
Old Nov 1, 2005 | 02:29 PM
redc3's Avatar
redc3
timing chain stretch
To Lars; I need your help on timing or anyone else
