I have an 81 vette. original Electric tachometer. For some reason the tach pointer is past 7 and motionless. The input signal is there. I removed the input signal but the pointer is still motionless past 7. I disconnected the battery and the pointer is still on the other side of the scale. Any Ideas?
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Most of the time it is the printed circut board....gone nutz...Eclkers Zip Corvette America all cary the part....you may also want to invest in a Tach filter to stop the spikes that kill Tach's
I would normally agree, but I think you emailed me about this earlier, and I haven't had a chance to respond. Is this an LS1 engine?
If so, the LS1 tach output signal is a 5V square wave signal with a frequency half that of a standard V8. Not sure what the tach board would do with this signal, but I bet it wouldn't work correctly. Your best bet is to use an aftermarket tach.
