Spark Plug type for Vortec heads
Old Nov 1, 2005 | 05:01 PM
79vetter's Avatar
79vetter
Default Spark Plug type for Vortec heads
AC Delco #41-932. Is this what you guys are running in yours? $5.95 each.
I had a little sticker shock at this one.
Old Nov 1, 2005 | 06:08 PM
cor79vette's Avatar
cor79vette
Thats approx what I was quoted for AC Delco at NAPA. The cheapest platinum tip plug was autolite at just over 2 dollars a plug. They had the part number in the computor data base.
Old Nov 1, 2005 | 08:52 PM
mandm1200's Avatar
mandm1200
5613611 R44LTS, set of 8
5614210 MR43LTS, set of 8
25164641 #3, rapid fire style, set of 8
P526S Accel U-Groove “SHORTY” Double Platinum Header Plugs approximately 3/16" shorter then R44LTS plugs, set of 8
I went with the AC Delco rapid fire plugs. Engine is still on the stand. After hearing negative things about the rapid fires, I will switch to regular plug if they mis-fire.
To Spark Plug type for Vortec heads
