Ride Height
Old Nov 1, 2005 | 09:38 PM
JIMS1970VETTE's Avatar
JIMS1970VETTE
Default Ride Height
After having the front end rebuilt, with new springs, and new shocks all around and having reversed the 7 leaf spring (I hope I did) as I pulled it out and forgot which end was which!! my 70 Vette still is low on the left rear, not much, but noticeable, what options do I have left.
Old Nov 1, 2005 | 10:05 PM
Jclgodale3's Avatar
Jclgodale3
factory mold flaw...IMHO. If you compensate (visually) with the left rear bolt, your "floor to fender lip" heigth will be about an inch taller on the left side rear vs the right side rear
Old Nov 1, 2005 | 10:09 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Maybe one quater panel was replaced and glassed on too low/high ??
You can compensate a little bit with the spring bolts but I wouldn't change it too much, maybe 1/2"
Old Nov 1, 2005 | 10:57 PM
chupacabra1974's Avatar
chupacabra1974
Could be. Mine has the same, and I know the history of the car back to 80 when my Mom bought it. No major work or accidents.
I had the front and rear suspension components all replaced at the same time, but still, the slightly noticeable lean to the left from the rear.
As much as I've read about the possible lean on cars even from the factory on these boards, I worry about it less and less...
...but then again, I'm always finding something else to obsess about "fixing" on this car.
IT NEVER ENDS...haha
Old Nov 1, 2005 | 11:45 PM
Jclgodale3's Avatar
Jclgodale3
I'm convinced...
Old Nov 2, 2005 | 10:19 AM
JIMS1970VETTE
Well I could try and adjust the left rear spring bolt and see what happens or pour 200 lbs of cement in the right rear to level it out Thanks for your guys input
To Ride Height
