Bubba built my hotrod
Old Nov 2, 2005 | 05:43 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Bubba built my hotrod
Eddie 70 is trying to walk me through my engine wiring and well.. I hit a road block.
found this fuse holder off the horn relay. I dont remember where I put the other end of it (6 months of not working on it will do that to you), nor do I remember where it goes to.
Anyone with a late 69 have one of these?
FWIW. . . I do have an aftermarket stereo in the car, but I re did the entire thing and I didnt put speakers in the engine bay.. I never had electric fans in it, not sure if someone else had them though.
Any help would be GREATLY appreciated
Old Nov 2, 2005 | 05:52 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Could it have been bubbas try and making a replaceable fusible link?
big_G's Avatar
big_G
That's the blower high-speed fuse holder, (original).
Old Nov 2, 2005 | 05:54 PM
Corz's Avatar
Corz
then what's it doing on the drivers side?
Old Nov 2, 2005 | 05:56 PM
Patrick73's Avatar
Patrick73
I agree with Gary. It looks like the one on my 73 which is on the driver's side--even though the AC blower, etc is obviously on the passenger side.
zwede's Avatar
zwede
That's where it goes. Bubba worked for GM in the late 60's. Wire goes from horn relay, inline fuse, across the firewall to the blower relay. Ugly, ugly, ugly.
Old Nov 2, 2005 | 06:00 PM
Fevre's Avatar
Fevre
Wish Bubba would stick to shrimp, damn you Bubba!
Old Nov 2, 2005 | 06:02 PM
Corz's Avatar
Corz
Insert bannable words here
Thanks guys.. I guess I'll just wear a jacket for now
Old Nov 2, 2005 | 07:18 PM
LFZ's Avatar
LFZ
i thought you sold that car??
Old Nov 2, 2005 | 10:00 PM
redc3's Avatar
redc3
everyone blames bubba for their own lacking
Old Nov 2, 2005 | 10:50 PM
Corz's Avatar
Corz
Eddie's car didnt have it, sooooooo I jumped to conclusions
sue me
Old Nov 2, 2005 | 10:55 PM
redc3's Avatar
redc3
dont take it seriously. i just like to stick up for the bubbas in all of us believe me if you could see what was done to my c3, youd help me hunt him down
Old Nov 3, 2005 | 01:18 PM
MoneyPit's Avatar
MoneyPit
The MoneyPit is not a Chevrolet, it is a Bubrolet. I feel like I should go find the previous owner of my car, and give him some more money for the options he installed. The latest that I have found is the "accessory" hole that he installed in the baggage compartment. It was covered with a piece of black painted fender and a nice seal of clear silicone, along with four screws for good measure. Bubba had stock in silicone I believe, as he used it to seal the tach drive port in the distributor, and the speedo cable.
Old Nov 3, 2005 | 07:52 PM
blctalon's Avatar
blctalon
Sounds like Bubba has been real busy lately making his rounds.
I'm finding new stuff everyday. From rigged up a/c hoses to broken a/c brackets. YES, a broken a/c bracket.
The one I found tonight is a improper carb install. My vette is a 78 with an L48. I would have reason to believe the engine is mostly stock, maybe a mild cam along with the edelbrock peformer intake. Bubba has found a way to bolt the Q-Jet to the manifold using the wrong adapter plate. It is a brand new Q-Jet bolted to some sort of adapter that only has holes for the front 2 carb mount bolts. All 4 spacer bolts are in the manifold but only 2 bolts holding on the carb. I don't think this is normal, maybe that's why it idles rough?
Old Nov 4, 2005 | 12:12 AM
Corz's Avatar
Corz
hmmmm I'd say it's got a bit of a vacuum leak
To Bubba built my hotrod
