Emission Test Failure - what to do?
My '02 Intrepid just failed it's emissions test because the "Check Engine" light was on. Local service station tech said it probably was a loose gas cap, so he reset the light, cleared out the memory, and had me drive it around for a day, then come back. The next day it passed. The light is not back on. The Dodge dealership would have "fixed" the problem with some new parts, for sure.
No one can convince me that dealerships don't EARN their reputation.
Just register the car outside of city limits (check county) but in Weld county you aren't required to have an emissions test. Easy way around it.
I recently posted a question about the emission laws in Arizona.I got a reply stating that the law was recently changed to exempt older cars from testing.Have you heard anything about this supossed new law?Thanks.
sorry to divert from the original poster.
I'll make some calls and find it where it's at this time. Crossed Fingers!
Lars,
You are correct, with a clause. He hadn't specified which range, CO vs HC. Adding TOO much CH3CH2CH2OH will push the HC up in many cases (especially stock or near/stock), unless it's been tuned rich for some unknown reason. (cam again?) As you know, many presume that more gas = more power and all their numbers go up when they start screwing with stuff. Plugs every 2 months sound familiar anyone?
Leaning it out across the board (artificially or through tuning) works in some cases.
I've also got some emissions before and after sheets that show just a bit cleans up the burn on both scales, partially burnt and non-burnt...... It's a matter of what state of tune the motor is in and what mix gets applied at the time.
1st and foremost verify the basics (spark, air, and compression) and tune accordingly. If his "project" has a bad plug or toasted rings timing changes will not get around that.
BTW- How do you tune around the overlap in a big cam?
That's raw fuel blowing past those exhaust valves...
Hey Robin, what's the overall feel for the way the motor is running?
Smooth, jumpy, ???
Please tell me there's no smoke...
Did the car sit for any length of time without fuel stabilizer. Air passages could be plugged up. Carb will need gone through.
How many miles on the engine? Carboned up chambers do not burn clean... etc, etc, etc,
Think beyond this test and get it tuned first.
VLTW!
I do not have the details as to what part of the emissions test failed - just that it failed. I will get the details on Monday.
I have no idea what the true mileage is on this corvette since the speedo and tach were disconnected. The air conditioning unit has been removed (due to the larger engine taking up that space). Most of the wiring inthe engine compartment has been cut, or just left hanging. The headlights do not pop-up. As I mentioned - its a real Project vehicle.
I did however purchase a brand new, out fo the box, Holley 4150 Carb (650 cfm), but that didn't seem to help it pass the emissions. There are brand new plugs, fresh oil, and new guts in the distributor. There is some (very minor) smoke coming out the right exhaust.
It was running VERY rough, but that was with the old carb/plugs. Since the shop has had it I have not seen it run.
Drop an email to Lars. He's in Colorado and is our resident guru...
Bone stock non-tuned for your specific app. I will leave that to Lars, the carb guru (aka The MAN), he's probably knows just where to set things for you.
Present entire time engine is running?
Worse under heavy throttle?
Getting closer!
Just tell him up front that your car won't pass emissions. He'll tell you it's $25 for the emissions test and $50 for 'adjustments'.
This is not an excuse for not tuning it properly, ESPECIALLY with Corvettes.
