Engine Died while driving....
Old Nov 3, 2005 | 03:34 PM
tmoneymoney4's Avatar
tmoneymoney4
Default Engine Died while driving....
started up fine this morning, started up fine this afternoon, infact pretty much 1 minute before the engine died... I was driving up a hill and shifted into 4th gear(not very steep) and the tach dropped to 0 and i couldnt get the car to power forward. electrical appears fine, radio works etc... my guess is Card or distributor... recently the carb screws were adjusted to lean out the mixture... could the car be getting to little gas?- i doubt it because i drove it 100 miles after that was done... so i checked the spark plug wires, two were loose on the distributor and i clicked them back into place. but i had already spent a few minutes pumping gas through the engine. could i have fixed it and its just flooded at the moment?
- the distributor just isnt sparking...?
please help, car is in a not so great place to be sitting for long,
thanks, alex
Old Nov 3, 2005 | 03:41 PM
MILO's Avatar
MILO
sounds like it may just be flooded now. Get a can of starter fluid and squirt a couple of seconds down the carb. If that doesn't fire it up then it's electrical. If it fires up then dies it's probably fuel pump/carb related.
Old Nov 3, 2005 | 03:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Is this HEI or a points car? If it's a points car, sounds like the points may have closed up or burned.
Old Nov 3, 2005 | 03:45 PM
81fastvette's Avatar
81fastvette
Check for spark. Coil or Ingition module may be bad. When they go it is like shutting off the car.
Old Nov 3, 2005 | 03:50 PM
Hauq`'s Avatar
Hauq`
If you were driving it, the idle screws have nothing to do with the stall. I would look into electrical, but not just the spark plugs, because the engine will still run if a couple of plugs aren’t working. Look into the power to the HEI coil. The other thing is fuel, it’s not terribly uncommon for the fuel pump to give out. If it will run for a little while on starter fluid then it’s probably your pump.
Old Nov 3, 2005 | 03:56 PM
onaqwst's Avatar
onaqwst
i know i flooded mine once...... i speed up to pass a truck to get off at an exit on the e-way and came to a stop light....... let the car sit and pushed the pedal all the way down and took about 4 turns of the key and it fired right up
b
Old Nov 3, 2005 | 04:21 PM
mvftw's Avatar
mvftw
If it's an HEI car, replace the distributor module. This will act up when hot, then work fine when cool... cheap & ez...
Old Nov 3, 2005 | 06:16 PM
tmoneymoney4
It didn't fire up 2 hours later, even with the starter fluid. That would mean its electrical then? How can i check for spark, i have no diagnosing machines etc... please help- towed my car home- ready to work on it
Old Nov 3, 2005 | 06:20 PM
GaryS's Avatar
GaryS
Do we know what year we are talking about? this usually helps.
Anytime an engine dies very suddenly without bogging down or slowly failing sounds like an electrical issue. If you have an HEI then I would do the diagnostic that is in the GM Service manual for your car. It will tell you if the internal coil is bad. You might also have a bad module under the cap.
If you have a standard points type distributor then I would check the coil for continuity. Your car may have a resistance wire in the line to the coil. If that burns through then you will have a dead car.
Again, a lot depends on the year.
Gary
Old Nov 3, 2005 | 06:25 PM
DMONSVETTE's Avatar
DMONSVETTE
Old Nov 3, 2005 | 06:33 PM
tmoneymoney4
Gary
76 Corvette 350ci
how do i check if its HEI? im pretty sure its a basic stock distributor replacement... (sorry im a newbie at this stuff, havent worked on this before)
thanks, alex
Old Nov 3, 2005 | 10:00 PM
tmoneymoney4
bump
Old Nov 3, 2005 | 10:19 PM
Perfomer's Avatar
Perfomer
Since no one answered you I will give it a try . You can tell if it is a HEI by pulling the plug wire off the distrubitor if there is a hole then it is a points type ,if there is a post sticking up it is a HEI type. You can check fire by holding the wire you pulled off close to the distrubitor while someone turns the ignition over . Be careful not to hold the wire to close so that the spark does't jump to you .
Old Nov 4, 2005 | 12:20 AM
Steve COSD's Avatar
Steve COSD
I had the same problem. Car would run fine for about 20 minutes. After that it would die. Replace the ignition module in the distributor. Make sure you use the silicone grease underneath the module. I believe this protects the module from engine heat transfer.
Good Luck!
Old Nov 4, 2005 | 08:11 AM
GaryS's Avatar
GaryS
Originally Posted by tmoneymoney4
76 Corvette 350ci
thanks, alex
I don't know for sure, but I thought 76s had a HEI. Can anyone chime in on this?
The stock distributor is much smaller in diameter than an HEI. In addition, the HEI has a built in coil whereas the non-HEI distributor will have a wire going to the external coil. If you have the GM Service manual for yur car, it will have a diagnostic for the distributor.
Gary
Old Nov 4, 2005 | 08:19 AM
djgrelli's Avatar
djgrelli
1975 was the first year to have the HEI Distributor. It was also the first year for the electronically driven tach because of new Distributor. Try a new module. I had one go out and the car stop dead in it's tracks.
Old Nov 4, 2005 | 11:28 AM
Nifty 71's Avatar
Nifty 71
Timing chain????
To Engine Died while driving....
Old Nov 4, 2005 | 12:03 PM
KenSny's Avatar
KenSny
Anybody who's going to be "working" on the engine needs a timing gun.
If you get the induction type you can connect it around one of the plug wires. Crank the engine and hold the trigger on the timing gun. If you see it flash you have spark.
Old Nov 4, 2005 | 12:04 PM
Bangkok Dean's Avatar
Bangkok Dean
Had the same problem with my new summit HEI. when it cooled down it started right up.
Old Nov 4, 2005 | 01:49 PM
kidneyboy's Avatar
kidneyboy
Happened to me two weeks after I got the car...same thing. It's a quick and easy fix.
