1976 Steering column question
Old Nov 4, 2005 | 08:09 AM
Chuck Pelton's Avatar
Chuck Pelton
Default 1976 Steering column question
Can a 1976 column be converted to accept a 1977-1982 steering wheel by changing the upper components from a 1977-1982 column?
Thanks,
Chuck
Old Nov 4, 2005 | 01:21 PM
Jim Shea's Avatar
Jim Shea
Yes, you can. In fact, I made the swap myself to my 1976 with T&T when the new leather covered steering wheels came out in 1977.
It just so happens that I have written a paper describing all of the necessary parts that are required. Here is the link.
http://www.corvettefaq.com/c3/T&T77-...To76Column.doc
The one thing that does happen, but it is no big deal, is that the 1977-1982 columns had less telescoping travel than the earlier 1969-76 steering columns (2.1 inches versus 1.3). Therefore, when you use a 1977-82 extension (the stamped can that covers the hub) on an older steering column, the new extension is a bit too short.
If you telescope your steering column so that the wheel is all the way back toward the driver you will actually end up with a small gap where the later extension is not long enough to completely cover the gap between the steering wheel hub and the steering column. Since most people don't drive with the steering wheel buried in their belly, that small gap is no biggie.
Good luck,
Jim
Old Nov 5, 2005 | 09:08 AM
Chuck Pelton
Jim,
Thanks once again for you help.
Chuck
To 1976 Steering column question
