Poor Gas Milage
Find out how far out the idle mixture screws are. Make sure they are even. Ok, starting wherever they were set originally open them evenly until the idle speed stops increasing. Now, turn them in evenly till you get a 50RPM drop in your idle speed. This is about as lean as you can get on the idle circuit and still have some driveability.
As far as leaning the carburetor, these things were calibrated lean from the factory. If you go too lean it could be forcing you to really lay into the throttle to get any performance out of it. Richen up the mains and you may not need so much throttle to move the car around.
BigBlockk
Later.....
be carefull I had a 600 double pumper on my 383 and it was not enough, put a 770 and it made a huge difference. mileage stayed about the same 8 in town 10 on highway
First of all, as Lars is apparently not here to say it, 90% of tuning problems are timing problems. 8 btdc, while factory recommended, is probably not optimal and definitely not what you need to be basing your timing on.
First of all, install lighter mechanical advance springs into your distributor (available at your local autoparts store as a kit). You might've already done this with the rotor? This will advance the timing much sooner which is good
Second, after you have installed this, check your timing at 3000rpm or so when mechanical is all-in. It should be about 34-36, set that and let the idle-timing fall where it may. As long as you are not getting knock (and most won't) that's all you need to do. You should get better mileage AND better performance from that.
Make sure your mechanical advance moves at all, just twist it by hand with the distributor cap off. Mine froze up twice on the original distributor and literally halved my mileage.
Once the timing is sorted out, only then is it time to get the carb to a good baseline. BigBlockk gave you some good advice. Keep in mind that the idle mixture screws and the idle speed settings both affect eachother. I don't know anything about Edelbrock carbs.
Oh, rather important information we need, how does it run?? Idle, cruise, acceleration, etc. Hope the convertor helps but even if that is the main problem you could still use some optimization.
Good luck
Chris
-Chris
You could change your fuel filter cheap and easy.
In comparison with 427 and 4.11 I get all around about 14 mpg.
There MUST be something wrong with these with such a low mpg and a highway rearend. Lockup auto just isn't enough to figure the loss.
You should be getting 16mpg on the highway with that setup, that's what I get with my q-jet and lock-up not working. However I had the dyno shop make my q-jet actually work properly and set my timing to 36 degrees total advance.
The carb is a q-jet, and the engine has not been "tuned up" that i know of, but was rebuilt just under 2 years ago (however, mismatched spark plugs make me question everything).
I think the rear-end is stock as well, but I can't seem to find the stamp to locate the ratio.
Brian.
