Solid rollers in a hyd roller block
Old Nov 8, 2005 | 07:27 PM
Gordonm's Avatar
Gordonm
Default Solid rollers in a hyd roller block
Having a discussion with another forum member (bobs77vette) about this. Does anyone make a solid roller that will work in a 86 or newer block that works with the spider. Most solid rollers I have seen have the locking bar style roller.
Old Nov 8, 2005 | 07:39 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Interesting question, someone is making one I bet and I bet Gkull would be the one to ask
Old Nov 8, 2005 | 08:29 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
seems like all the performance equipment is geared mainly for the pre 86 market
Old Nov 8, 2005 | 08:36 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Yep
Old Nov 8, 2005 | 08:45 PM
Gordonm's Avatar
Gordonm
I would not say that. Look at all the stuff already out for the LS1 motors. There is plenty of performance crank rods and pistons for the roller, 1 piece rear seal blocks. The solid rollers with the link bars would most likely fit the roller blocks, maybe the spiders will just not hold a solid roller tight enough at high rpm. Anyone else with knowledge on this?
Old Nov 9, 2005 | 10:38 AM
Fevre's Avatar
Fevre
Here ya go, crane part # 10510-16 (set of 16), had to search by crane part # to pull it up on summit's website
http://store.summitracing.com/partde...=KeywordSearch
Old Nov 9, 2005 | 01:13 PM
jimmygmartin's Avatar
jimmygmartin
Do they have oiling provisions?? ie.oil groove or passage to the roller??
Old Nov 9, 2005 | 02:26 PM
Fevre's Avatar
Fevre
Note sure, info is at www.cranecams.com
EDIT: No info there, might need to call the tech line.
Old Nov 9, 2005 | 02:43 PM
bobs77vet's Avatar
bobs77vet
well those solid rollers look like they are the ticket..i wonder if they are noiser then regular solid lifters? i'm thinking they will be quieter
To Solid rollers in a hyd roller block
