Clutch problem
Old Nov 9, 2005 | 02:40 PM
conway62's Avatar
conway62
Default Clutch problem
Clutch slips when the care is warmed up. I can chirp the tires when I first take off. After about 10 min of driving the clutch will slip from a stopped position. Any ideas?
Old Nov 9, 2005 | 02:51 PM
djgrelli's Avatar
djgrelli
Sounds like it's time for a new cltuch and pressure plate. However, it could be you're leaking oil from rear main seal and it is getting on the flywheel causing it to slip after warm up. Do you notice any oil puddled under the car.
Old Nov 9, 2005 | 03:03 PM
zwede's Avatar
zwede
Check the freeplay adjustment. Pedal should have about 1" of travel before it starts disengaging the clutch.
Old Nov 9, 2005 | 03:04 PM
conway62's Avatar
conway62
No oil leak I can detect. There is about 2000 miles on my rebuilt 454. Everything looks dry. The clutch and Presure Plate have about 3000mil on them. Also had the flywheel resurfaced when I had the motor rebuilt.
To Clutch problem
