More brake problems
Old Nov 8, 2005 | 10:06 PM
silverslashstreak's Avatar
silverslashstreak
Default More brake problems
I know this has been covered before, Here is the question? I am working on sons 73 and we have been chasing the brakes for a few years. I can't get a good solid pedal.
We have put on 1 new booster and 3 master cylinders. The calipers are stainless and don't leak and I don't think they are sucking air. The car will stop ok but always seems to have mushy pedal.
I am wondering if the porportioning valve could be a problem or maybe the rod from the pedal isn't adjusted out far enough (we put in clutch and brake pedals to switch from auto to standard)? Any help would be great. Thanks SSS
Old Nov 8, 2005 | 10:18 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Did you change the brake hoses? Any kinks in the brake line?
Old Nov 8, 2005 | 10:31 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
How did you bleed the system ? You'll find many different opinions on this subject but pressure bleeding is the best method IMO..
Try the stainless braided hoses
Old Nov 8, 2005 | 10:58 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Then your car is NCRS perfect. They came that way from the factory.
Old Nov 8, 2005 | 11:31 PM
silverslashstreak
Default mushy brakes
Yep, we used steel braided lines , I thought we had a soft rubber line. Been bleeding these things for years and finally broke down and bought a motive products pressure bleeder, thought that would help, but no luck. Any more ideas? SSS
Old Nov 9, 2005 | 08:07 AM
mandm1200's Avatar
mandm1200
Bleeding the lines/calipers only helps if there is air trapped inside. When you bleed them, are you getting any air out of them? I attach a clear plastic hose, approx 1/8", to the bleeder until I see a stream of fluid without the tiny air bubbles.
In my opinion, new cars today have a slighly different feel in regards to the brake pedal effort.
Old Nov 9, 2005 | 09:11 AM
GDaina's Avatar
GDaina
Try again, do the pressure bleed...don't know if yours is air powered or do you pump the pressure by hand, but use a low pressure, and tap on the caliper with a hammer to dislodge any air bubbles. When you get a nice steady flow, remove the pressure bleeder, then open the bleeder and let it flow by gravity, again tapping with a hammer. Do that for each wheel.
Don't forget to check your MC for fluid level.
Did that to mine and have a rock solid pedal, though I used a pressure bleeder that I made and 5 lbs of air.
Old Nov 9, 2005 | 10:48 AM
silverslashstreak
Default Ill try it again....
I didn't know what pressure to use.... I just pumped it to 10lbs. I will try it at a lower pressure and maybe do a little tapping.
Old Nov 9, 2005 | 10:50 AM
silverslashstreak
Default Mushy brakes problem
Thanks for the suggestions, I have run 4 cans through and used the clear lines and we think we have all the air out. I even gave up and took it to the guys at the shop that do all my normal brake and tie srevice and they are stumped.
I think we have some kind of strange problem in lines or porportion valve or something that doesn't occur normally.
Thanks for the suggestions SSS
Old Nov 9, 2005 | 10:59 AM
norvalwilhelm's Avatar
norvalwilhelm
I'm a big believer is getting rid of the proportioning/light switch. You can totally remove it or modify the block so it actually is just a dummy and the 2 systems/front and back are totally seperate.
You do not need a proportioning valve with our cars.
Old Nov 9, 2005 | 11:43 AM
silverslashstreak
Default porportioning valve
Hey Norval, I agree, I have been running a dual master cylinder with disc on my 63 for years and a divided system with no porportioning valve and have no trouble and it has good balance. I was just trying to make the stock system work, but I am thinking about pulling the valve and give that a try. They say that a porportioning valve can cause funny thigs to happen.
Thanks SSS
Old Nov 9, 2005 | 12:09 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Since when are power brakes firm?
You can push them to the floor if you want to. It's the booster that causes it.
Only manual brakes feel hard.
Old Nov 9, 2005 | 12:25 PM
mandm1200's Avatar
mandm1200
You may not need the proportioning valve, but I don't think having one will cause a mushy feel of the pedal.
Old Nov 9, 2005 | 07:58 PM
C3 Stroker's Avatar
C3 Stroker
I would go higher with the pressure......first pressurize the system to 20 lbs. with the bottle empty; if you have ANY leaks, this will reveal them. If this holds for a minute or so, slowly release the pressure and introduce the fluid using 20 lbs., and bleed. Any air will quickly come out.
Old Nov 9, 2005 | 08:11 PM
45ACP's Avatar
45ACP
Don't forget that there are TWO bleeder screws on each corner out back. Folks have been known to overlook/forget that and get very frustrated with the results.
Old Nov 9, 2005 | 08:41 PM
68sbShark's Avatar
68sbShark
For good measure, replace the bleeders too. You can get them at AutoZone. The PO of my 68 turned them in too tight and smashed the bottoms of them so bad that they cracked and leaked. Took me a few hours and a few choice words to find the leaks.
~Rich
Old Nov 10, 2005 | 08:14 PM
MAZ73's Avatar
MAZ73
Ahh, brakes, my favorite. Just finally got a solid pedal on my 73. Did you bench bleed the new master cylinder first?? I have ran about 6 quarts of brake fluid through mine using one of those hand pump pressure bleeders. After months of frustration and sore hands, I was finally able to get good pedal this past week. Was starting to worry about the prop. valve myself. Air is a bi*** to get out! Good luck!
Old Nov 10, 2005 | 09:34 PM
DR.Jay's Avatar
DR.Jay
Default pressure bleeding
My pressure bleeder is a 25yr old Red Head. When I rebuilt the calipers on my '78 my wife got the great job of pumping until it was hard. I just use the time honored tradition of break bleeding passed onto me by my fore fathers. She just pumps the pedal until it gets hard, and I crack each bleeder open in the standard bleeding procedure.
To More brake problems
