Hood latch help
Old Nov 8, 2005 | 11:20 PM
edhand's Avatar
edhand
Default Hood latch help
Is there another way to open a stuck hood besides the screwdriver in the cowl? Considering the cable is rusted solid, the latch may be, also. I don't know if that's the problem, or I'm not getting the screwdriver in the right place, but i've been trying for 2 days now, and no luck...
TIA
Old Nov 8, 2005 | 11:44 PM
jdp6000's Avatar
jdp6000
This should help
http://www.madvet.com/shop?frame=1.264.3852
Jim
Old Nov 9, 2005 | 12:55 AM
edhand's Avatar
edhand
That's what I've been trying...it's not working!! Ahh!!
Old Nov 9, 2005 | 07:28 AM
Jclgodale3's Avatar
Jclgodale3
I reached up through the side vent grills (with them out) on a 71 and was able to locate the release on each side...good luck!
Old Nov 9, 2005 | 08:33 AM
second76's Avatar
second76
On my '76, with the front wheels off, I was able to reach in from the wheel well and grab the release.
Old Nov 9, 2005 | 04:20 PM
vetteboy1976kr's Avatar
vetteboy1976kr
I tried that mid america procedure for about three hours and got nowhere. You can remove the splash shields (bottom, just in front of cowl; triangular shaped) and reach way up to pop the release. You can also take the two bolts out of the hinges and twist the hood side to side and it will release BUT you will have to re-align the hood with the latches. The latter is not recommended if your paint is nice unlike mine. Keep us posted!
Old Nov 9, 2005 | 06:12 PM
70 LS1's Avatar
70 LS1
What year is your car?
Old Nov 9, 2005 | 11:33 PM
edhand's Avatar
edhand
It's a 76...it's a car I picked up last weekend that hasn't moved in 8 years, so everything is a bit rusty. As far as the paint, it's not in the greatest shape. I jacked the car up and tried to reach up, but I couldn't find it...I'm not sure what splash shields you mean? I can't go through the wheel well, I think the inner wheel well is riveted to the fender. I may have to unbolt it from the front....
Old Nov 10, 2005 | 01:44 PM
davidm_comp's Avatar
davidm_comp
I know this may not help you but, I think that the cowl is the best way to open the hood, assuming the latch isn't rusted solid. I practiced on mine with hood open many times and then with hood shut, just incase the cable snapped I would know how to open it. All I can say is it does take patience and a sensitive touch. Good Luck...
David
To Hood latch help
