I am getting close to installing my 4 spd trans. and engine back into the car...
Should I install the shift linkage and shifter onto the transmission before installing into the car? I seem to recall that the shifter is difficult to get to once the transmission is installled..
I installed them the engine and trans together. I use a hurst shifter and set it up(shift rods)before I replaced the trans to get it right, then removed the shifter for the install because clearance is tight then put it back on. Not to bad a job.
Info for people who haven;t worked on their stock Muncie shifter......... The shifter is not attached to the transmission. It's attached to a bracket that's mounted to the trans crossmember. The last time I installed a transmission, the shifter was in place with the shift rods hanging down. After installing the transmission, then attach the rods to the transmission levers.
Kinda looks like if you jack up the rear end and tilt the engine using a leveler, it should work.
I agree and having the radiator support bolts out and being able to tilt it forward if needed will help also. I pre-adjust my Hurst shifter and install it through the floor opening after bolting in motor/transmission unit.
Put the car on jack stands, remove the front wheel and go in from the side. This makes it very easy to install engine and trans at one time. The use of an engine leveler is a must.
