headlight door hinge bearings...
Old Nov 11, 2005 | 03:33 PM
petty44's Avatar
petty44
Default headlight door hinge bearings...
man do these things suck to change outboard side you can't even see the 3 bolts, the "good Dr." had all the parts I needed should have the drivers side done today.. I dread doing the passenger side! this will clear up the shakey headlight! bushog
Old Nov 11, 2005 | 04:02 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
might be easier to drop the wole headlght assy, 2 bolts in back, 2 in front...
Old Nov 11, 2005 | 04:56 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I saw a kit at the Fall Corvette Expo in Knoxville that had all of the bushings and bearings, new springs, all new pins etc... to rebuild the headlights buckets for $115. I thought about buying it but was not really ready to open that can of worms yet. If I see it next spring, I may just buy it and put it on the shelf for later on sometime.
Keep plugging at it and it should pay off when you get it all done.
Old Nov 11, 2005 | 05:29 PM
GTR1999's Avatar
GTR1999
Bairs has a complete headlight rebuild kit for under $90. I used it on a coule of cars and it has all you need. You do need to remove the buckets-PITA job
Gary
Old Nov 11, 2005 | 06:53 PM
A72COUPEDT's Avatar
A72COUPEDT
427V8 and Gary are correct...drop 'em!
Old Nov 18, 2005 | 07:40 AM
petty44's Avatar
petty44
left side is done!!! now on to the right side, I will also need 1 relay valve, door was slow to come up swapped with the right side and the problem followed where should I get the valve from... heard the repro. valves are not very good?? thanks bushog
Old Nov 18, 2005 | 08:32 AM
Eddie 70's Avatar
Eddie 70
Another thing I have heard of some doing is just using the one relay to drive both headlights. Just use a few T's and it should work. I have thought about doing this myself but never did try it.
Old Nov 18, 2005 | 09:41 AM
73'Vette's Avatar
73'Vette
It does work. This is how mine is now functioning.
To headlight door hinge bearings...
