Carburetor (timed vacuum vs. full vacuum advance?)
Old Nov 18, 2005 | 12:49 AM
Farm_Kid's Avatar
Farm_Kid
Default Carburetor (timed vacuum vs. full vacuum advance?)
Do Corvettes have a standard set-up when it comes to timed vacuum or full vacuum advance? What does the vacuum advance do for the car in the long run?
The instructions for my carb install tell me to determine between the two, but since the car doesn't run with the current carb, I can't start it and "feel" for vacuum, I don't know which vacuum port on my Edelbrock 1406 to connect it to.
Old Nov 18, 2005 | 12:58 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
You can run it on either. Do a search of this forum. There's about 2 zillion threads on the subject.
Old Nov 18, 2005 | 06:46 AM
Gordonm's Avatar
Gordonm
Someone post a link to Lars papaer on this. It explains it in detail.
Old Nov 18, 2005 | 09:01 AM
henderjl's Avatar
henderjl
Default Which Vacuum to Use
What you refer to as "timed" vacuum I think is more commonly called "ported". Ported vacuum is zero at idle, but comes in when you open the throttle. To see the effect, get an inexpensive vacuum test gauge and run a hose from the carburetor to the passenger compartment. Drive around and watch how the different ports affect the gauge.
My car tends to surge a bit more at very low engine speeds with the throttle closed and with the distributor connected to full vacuum, say turning into a driveway, so I am using ported vacuum. Try it both ways and see which you like better. You will have to adjust the idle stop when switching ports.
The purpose of vacuum advance is for gas mileage. A car gets better mileage with lots of advance, but too much advance causes preignition at large throttle openings, so the vacuum advance mechanism gives more advance at small throttle opening (high vacuum), but shuts off and leaves advance control to the mechanical advance at larger throttle opening. On my big block '71, this is worth about 1 mpg. Doesn't sound like much, but it is a 10% increase over no vacuum advance.
Since your car is not running yet, hook the vacuum advance to either port or leave it disconnected. It doesn't matter that much. Play around with it after you get the car running right.
Old Nov 18, 2005 | 10:09 AM
David Ey's Avatar
David Ey
What determines which is ported and which is full vacuum? What I mean is how do I know by looking at the different locations on the carb and manifold which will be what?
Old Nov 18, 2005 | 10:53 AM
MCCA76's Avatar
MCCA76
When looking at the front of the carb, the ported vac is to the left, the pcv in the center and manifold vac to the right. After tuning the car per Lars, my 76 runs/performs better with the manifold vac connected and the ported blocked.
To Carburetor (timed vacuum vs. full vacuum advance?)
