Starter motor shimming?
Old Nov 18, 2005 | 05:45 AM
UKPaul's Avatar
UKPaul
Default Starter motor shimming?
Hi,
When setting the starter motor clearance with shims you can get it bang on by shimming it until a certain size drill bit fits snugly ie. stick a small screwdriver through the hole in the motor & use it to lever the gear out so that it meshes with the ring gear, then check the clearance between the peaks & troughs of the meshed teeth by using the drill bit. Simple, but I've completely forgotten the size of drill to use, does anybody know what it is???
TIA
Paul
Old Nov 18, 2005 | 07:56 AM
brianlewis60's Avatar
brianlewis60
1/8" tween the teeth and you will be spot on perfect
Old Nov 18, 2005 | 09:32 AM
UKPaul's Avatar
UKPaul
Thanks Brian
Old Nov 18, 2005 | 10:34 AM
brianlewis60
not a problem just finished shimming up my big block last night so I just happened to remember
Old Nov 18, 2005 | 10:57 AM
Todbo's Avatar
Todbo
I having problems with my new mini starter on my BB , I hoped the shims would be the same as my old one , but no. The mini engaging ok but seems to stay engaged too long after the motor fires , I'm guessing it's a shim problem , I'll try to follow your advice here guys.
To Starter motor shimming?
