Engine tapping
Old Nov 11, 2005 | 08:20 PM
Crab's Avatar
Crab
Default Engine tapping
I just started hearing the engine tapping today after a 7 mile drive.It's a stock 350 with 17,535 miles on the car(1980) and it also started to run a little bit rough. Any ideas as to what it could be?
Old Nov 11, 2005 | 09:10 PM
comp's Avatar
comp
may be a rocker backing off
Old Nov 11, 2005 | 09:12 PM
kona's Avatar
kona
Exhaust leak?
Kona
Old Nov 11, 2005 | 09:13 PM
big_G's Avatar
big_G
Cam with a flat lobe?...uuggghhh.....
Old Nov 11, 2005 | 10:09 PM
Crab's Avatar
Crab
It's not the exhaust, sounds like the driver side and one of the cylinders toward the front. More like a knock than tapping and not a steady knock, fades in and out at idle, but louder when you increase rpm's.
Old Nov 11, 2005 | 10:24 PM
rihwoods's Avatar
rihwoods
Could be a broken valve spring...get a very long screwdriver and listen at the valve cover..then remove that valve cover and look at intake/exhaust very carefully...
Old Nov 12, 2005 | 07:36 AM
fl_rider's Avatar
fl_rider
Default Quoth the raven, `Nevermore.'
Once upon a midnight dreary, while I pondered weak and weary,
Over many a quaint and curious volume of forgotten lore,
While I nodded, nearly napping, suddenly there came a tapping,
As of some one gently rapping, rapping at my chamber door.
`'Tis some visitor,' I muttered, `tapping at my chamber door -
Only this, and nothing more.'
Or it could be a lifter gummed up from only driving it an average of 701.4 miles per year.
Old Nov 12, 2005 | 07:52 AM
73convertible's Avatar
73convertible
Edgar Allan Poe at 7:36 AM on a Saturday. Boy your good!
Old Nov 12, 2005 | 07:56 AM
fl_rider's Avatar
fl_rider
Thanks but the hard part was the math
Old Nov 12, 2005 | 08:13 AM
73convertible
Tell me you did not use a calculator and I will be amazed
Old Nov 12, 2005 | 08:22 AM
kb2fzq's Avatar
kb2fzq
I always thought a "knock" involved a rod....I'll have to watch this one and learn...
Old Nov 12, 2005 | 08:34 AM
rihwoods's Avatar
rihwoods
Carbon "knock" ????
Old Nov 12, 2005 | 09:04 AM
Crab's Avatar
Crab
That's not the average, over the last two years. I've driven it about 2500 miles per year. The original owner drove it 11,676 miles in 23 years. I just started useing a synthetic blend oil (Castrol) about 700 miles since oil change. I've heard that synthetic oil will clean a engine and sometimes cause leaks and other problems. Any other thoughts?
Old Nov 12, 2005 | 10:11 AM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Ahh synthetic .Synthetic is pretty pointless if you dont have a new motor, the synthetic allows you to use tighter clearences becuase synthetic is much thinner almost like water . Maybe you have carbon build up in that cylinder and it's increasing compression and causing it to knock
Old Nov 12, 2005 | 05:48 PM
Crab's Avatar
Crab
I did'nt use 100% synthetic I went with a syntetic blend. Started it up today and it's getting worse, sometimes at idle it knocks loud and the motor jumps . Now I'm scared its more than the things in previous posts. What is the worst thing it could be?
Old Nov 12, 2005 | 10:36 PM
DR.Jay's Avatar
DR.Jay
Rod knock. The Easiest way I know how to diagnose the problem is to pull each spark plug wire off one at a time at light load. When the the engine stops knocking you found the bad hole.
It sounds bad though.
Good luck!!!
DR. Jay
Old Nov 12, 2005 | 10:54 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Good luck!!!
DR. Jay
This is how I trouble shot mine on Wednesday. Have someone sit in the car and hold the RPM at the level which you here the noise. Use insulated gloves and a pair of good pliers/multi-grips to pull of each wire fromt the distributor. Remove/replace each wire and listen for the sound to change. The noise will vary as you remove the load from the weak cylinder. I hope yours is not as bad as mine.
Cheers,
Pete
To Engine tapping
Old Nov 13, 2005 | 06:08 AM
kb2fzq's Avatar
kb2fzq
Here's a crazy idea...how about running down to the oil change shop and giving the ole' girl a quick oill change...worst can happen is a waste of 40 bucks...but maybe it'll help...that would be my first move...just for the heck of it..I'm wondering if you were out hammering on her right before the knock started...if you really had the RPM's up there right before the knock, I'd say ya gots some major problems...
Old Nov 13, 2005 | 08:27 AM
rihwoods's Avatar
rihwoods
Try misting water down carb keeping revs up...make sure it is misted in from a spray bottle...I'm betting on the carbon knock...have you tried listening with a long screw driver at valve cover yet ? If the noise is near top of engine,chances are it is not a rod..hopefully...
Edit:I was fooled by a carbon knock once..dropped the pan,and everthing was ok....ever since then,my first move is to probe engine and listen with a long screw driver or wood dowel...never had auto shop,either...
Old Nov 13, 2005 | 09:06 AM
DR.Jay's Avatar
DR.Jay
Feeding the engine a water mist is a great way to remove carbon deposits from the combustion chamber, and stop predetonation.
I use a primative system that drafts a 50/50 water/methenal vapor mix from a used winshield washer tank that I sourced from a mid '70s chevy pickup. I have a system on my wife's '89 subarban, and I also have one on my '95 z-28.
It really helps lower egt. on the camaro, and It also totally stoped predetonation in the suburban.
Just (Google) "water injection systems". you can find very primitive systems to very high tech. I think that installing a water injection system on any internal combustion engine is a must.
I hope it is just carbon Knock, and not a spun rod bearing!!
DR. Jay
