Radiator support HELP!!!
Old Nov 12, 2005 | 09:43 PM
A72COUPEDT's Avatar
A72COUPEDT
Default Radiator support HELP!!!
I was working under the car installing the headlight buckets and found two REALLY RUSTY pieces...
#1:Radiator support. (these rust out?)
#2 Front crossmember. (replaced)
I am ready to replace the radiator support and found that most SBC/Auto used a 26" radiator.....IS THIS CORRECT??
Thanks in advance!!
Dave
Old Nov 12, 2005 | 09:48 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Old Nov 12, 2005 | 10:49 PM
big_G's Avatar
big_G
Thanks in advance!!
Dave
The radiator supports are year and option specific. Make sure when you order the replacement you specify the year, engine size and a/c or no a/c. Most s/b engines use the 26 in., b/b usually 27 in. G/L
Old Nov 13, 2005 | 01:25 AM
Glassbowtie77's Avatar
Glassbowtie77
I believe that there are currently 2 used ones on Ebay that you may want to check out. Mine was also totally rusted out at the bottom when I got my car. I bought a rust free one used on there and paid $175.00 for it, new they go for $350.00 or so. All I did was run over it with some sandpaper and then I primed it and then painted it with several coats of Rustoleum Professional Gloss Black Enamel. It looks brand new for half the price. I sprayed my radiator brackets also and transferred them to the new support along with new rubber cushions on the top and bottom and then I installed a brand new radiator as well.
Old Nov 13, 2005 | 04:24 PM
A72COUPEDT's Avatar
A72COUPEDT
Thanks for the tip...the one guy from New Mexico is selling a nice one but I have a source that says it's from a 77-79 non a/c car. If you look closely he bored a hole(passenger side) for the a/c hoses into the support(not good). I asked the other ebay guy if his was year & transmission correct. NO response thus far.... I found through research I need a 26" copper for a 350/auto transmission. Hopefully with NO rust please...anybody?
Thanks, Dave
Old Nov 13, 2005 | 05:32 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
I have patched a few with a MIG but it depends on how bad it is. It is a structural support that helps hold the nose up so if its really bad, replace it.
Old Nov 13, 2005 | 06:59 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
All 69-72 small blocks with either AC or Auto used the 26" support and a copper/brass radiator. LT1's and L46 also used this package.
All 69-72 big blocks used the 27.5" support.
We sell a brand new one reproduced from original GM tooling for $295
here the link
To Radiator support HELP!!!
