Car is sqeaking, what could it be?
Old Nov 13, 2005 | 01:12 PM
knkayotte's Avatar
knkayotte
Default Car is sqeaking, what could it be?
I’ve got a squeaking sound coming from the cars left rear. It is continuous and varies in conjunction with the speed of the car. Don’t think it’s the wheel bearing; I’m thinking something to do with the parking brake.
Anybody have this issue before, would of done a search, but, well you know. Just looking for a heads up of what it might be. Won’t be able to tackle the issue for a couple of weeks.
Keith
Old Nov 13, 2005 | 01:20 PM
Chopper Larry's Avatar
Chopper Larry
U-joint(s) would be my bet....get all 6 done at the same time.
Old Nov 13, 2005 | 04:01 PM
LYLE's Avatar
LYLE
The springs rust and break then they grind in the bottom of the E-brake drum. Very common problem.
Old Nov 13, 2005 | 05:13 PM
knkayotte's Avatar
knkayotte
Thanks, not use to all the C3 issues..........yet.
Keith
Old Nov 13, 2005 | 08:03 PM
vette64772's Avatar
vette64772
The brake calipers are most likely moving back and forth on the calipers pins. Mine did the same thing. Do a brake job, or at least change the pins out for new ones. I am almost sure this will be the fix. You could block up the rear end and put it in gear to check if this is it.
To Car is sqeaking, what could it be?
