PVC valve issue?
Old Nov 14, 2005 | 01:15 AM
76mike's Avatar
76mike
Default PVC valve issue?
Stock '76:
I tuned the o'le q-jet and timed the engine tonight, but when i went to put the aircleaner assembly back on, the engine ran like crap. The problem came when I hooked the line from the side of the carb to the assembly. Is this a bad PVC valve? Just a thought. Any help? The engine was running fine before, and when I take the line off of the assembly it runs great.
Old Nov 14, 2005 | 01:43 AM
Civis's Avatar
Civis
When you shake the PCV valve, does it rattle?
Old Nov 14, 2005 | 02:50 AM
comp's Avatar
comp
put a new hose and PCV valve on it and check the gromet(spelling) in the valve cover
Old Nov 14, 2005 | 08:02 AM
kb2fzq's Avatar
kb2fzq
Sounds like a vacuum leak...I agree with Comp above
Old Nov 14, 2005 | 08:05 AM
kb2fzq's Avatar
kb2fzq
Also double check and make sure you put everything back on the same way you took it off.
To PVC valve issue?
